Old Fri 19 July 2013, 20:56
Kevin Duan
Just call me: Kelvin
Shenzhen
China
A Simple Introduction of CNC System
CNC Work Systems
A CNC router is actually a part of two dependant systems which must be employed in order to produce anything. There is a Design System and a Fabrication System. The Design System is comprised of the Concept, CAD/CAM (and files), and the CNC machine. The Fabrication System is comprised of Work holding, and the CNC machine.
The Design System starts with some kind of Concept of what you want to achieve.
The CAD/CAM phase involves drawing and/or use of preexisting files in order to bring that Concept to reality. The output of this phase are the tool path files the machine will use.
The CNC machine itself is involved because it dictates what can and cannot be done in particular dimensions, this has an effect on how the tool paths are made (design). How fast you can move the cutter is also machine dependant and impacts how you design the tool paths.
The Fabrication System starts with some piece of stock that must be affixed to the machine. This is called work holding or fixturing. The task and material may require some special way of affixing the stock or even a dynamic clamp that is part of the CNC machine itself. Fixturing is a constant issue when it comes to using the machine. If you process even a few different materials or stock configurations you will need multiple methods of work holding techniques. The CNC machine is (naturally) a component of the Fabrication System as well. The machine must be setup and reset with known references and often tool changes must be accomplished during fabrication.
Removed signature lines with phone numbers and e-mail address
Last edited by Gerald D; Fri 19 July 2013 at 21:07.. Reason: Signature lines removed
Simple gear design ?? alan254 Graphics & CAD 6 Wed 23 May 2012 22:12
Introduction - Wylie, USA Todd Fox Introduce yourself and start planning 2 Thu 09 July 2009 14:31
A very simple sanding device gixi Miscellaneous / General / Whatever / Catchall 2 Mon 29 June 2009 07:14
Comparison: MechMate 4'x8' System to the EZ-Router 4'x8' System dmoore Archives 0 Thu 22 May 2008 10:23
G-Simple (free) Gerald D CAM 0 Wed 02 April 2008 12:44
