Old Mon 10 June 2013, 14:36
Wayne Webb
Just call me: 3Dsigns
Chipley, FL
4 1/2" Grinders
Which brands and models of 4 1/2" grinders fit the lazer-cut skate? Which do you recommend? I would like one with high amps. Thanks
Old Tue 11 June 2013, 16:21
Wayne Webb
Chipley, FL
Ok......i went ahead and ordered a set of two Dewalt grinders Model DW818, off Ebay, for $119.95 9 amps each. Someone on another thread said they fit his so, here's hoping.
While I'm waiting on my skate components to arrive I'm designing and cutting out the sheet metal for the controller on my Shopbot. It's going to be a 9'x8'x5' 5-axis hotwire foam cutter., framed out of 80/20 aluminum and powered by timing belts and 525 in/oz steppers.
Old Sat 15 June 2013, 05:50
zumergido
Just call me: Fernando
BS AS
i use the 900w dewalt 818. works great
becarefull has far i know only this model of dewalt works on the skate.
Old Mon 17 June 2013, 08:44
Wayne Webb
Chipley, FL
Thanks!
My two 818's are supposed to arrive by wednesday.
Driving an "indexer" , or a ("4th") rotary axis edrowell Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 14 Sun 28 June 2015 16:41
A record of burnt out grinders . . . . Alan_c Rails & Rollers 18 Wed 18 May 2011 04:58
Some alternatives to Bosch grinders for skate dmoore Rails & Rollers 17 Mon 22 March 2010 03:47
"Gecko 540" vs. "PMDX-122 & Geckos 203V" kanankeban 701. Motor Drives 10 Thu 19 February 2009 08:19
