Go Back   MechMate CNC Router Forum > After Building the Beast - Operating , Troubleshooting and Maintenance > Maintenance
Old Mon 22 April 2013, 09:31
2.2kw Spindle bearings
After two years of use my bearings gave up after some MDF routing.
Spindle is very easy to disassemble, inside are two angular contact bearings in the nose 7005 and one 7002 on top. Very strangely arranged but ok...
After looking at spending 300$ on these three bearings I found a good source (SKF) and bought some spares for future use, he also had some cheaper brand but these were cheap enough. Idea of buying another spindle with chinese bearings was out of question as I will be upgrading to a more powerfull one in the future and don't want 2 of these
Will post pictures later after assembly, anyone interested in these bearings can contact me.
Old Tue 23 April 2013, 03:01
Danilo, did the $300 include the spares?
Old Tue 23 April 2013, 03:03
Oh! and which bearing(s) actually failed?
Old Tue 23 April 2013, 03:25
First lower 7005 bearing failed but others have some marks on the bearing balls to so they are not far from failing too
Yes I got a paired set of 7002 and one spare 7005, they are all ABEC 7 = ISO Class 4 = DIN P4 2.5um runout rated
Old Sat 22 June 2013, 15:17
Danilo,
Angular contact ball bearings, SKF high- and super-precision?
Old Sat 22 June 2013, 15:38
Yes, I have pictures somewhere but I forgot to upload them here to show.
Can't dig them out on my laptop, I'm away from home now but will post them soon as I find them.
Old Sat 22 June 2013, 15:54
Here it is
Grease I used is LGLT 2, I wanted LGLC2 but it seems it is not manufactured anymore.
I asked for KLUBER Isoflex NBU 15 but they asked an arm and a leg for it ... around 250 EUR for 200gr no smaller packs.
Old Fri 20 December 2013, 18:15
Sorry so late. Thanks for the info.
Anyone need more bearings? MELBOURNE rotorzoomer The Market Place 1 Fri 12 February 2010 06:45
Spindle Bearings replacement CAM Craft 50. Toolheads 40 Mon 03 August 2009 04:46
Bearings precision levels isladelobos Miscellaneous / General / Whatever / Catchall 1 Sun 12 July 2009 20:57
What are the size of the 8 bearings on the skate? lumberjack_jeff Rails & Rollers 1 Tue 16 June 2009 18:44
