Old Thu 07 March 2013, 05:18
Andrew_standen
Just call me: Andrew #109
Dorset
Will my legs be strong enough
I've got some 80 x 80 x 2mm sections long enough to use as legs, will this be strong enough to take the weight.
As I am going to be a bolted frame, can I weld 5mm plates to 2mm section, just tacking at the edges or will it burn through.
I'm a very newbie to welding..... gonna borrow one this weekend, never used one before?
cheers
Andrew
Old Mon 11 March 2013, 21:07
David Bryant
Just call me: David #99
Western Australia
Changing from the plans can always be fun... But it always opens a can of worms.....
Dont just tack.
80 x 80 x 2mm would take the weight applied if fully welded.
2mm can burn through while you are learning to weld often easier to start on 3mm+
Usually weight is an advantage in the base and helps it stay put for accelerating the bits that move, or fill with cement
David
Old Tue 12 March 2013, 16:23
Andrew_standen
Dorset
Thanks David.
I've done some calcs and each 720mm leg will weigh 4.7kg, so I'm going to fill with dry sand, that will add 6kgs to each leg.
Steel arrives this friday and will start welding this weekend.
I just wanted to use up these ( 8 off ) 80mm by 80mm by 1800mm steel sections rather than take them to the scrap heap.
Will weld all around, thanks for your advice.
Andrew
Old Wed 13 March 2013, 01:45
David Bryant
Western Australia
You might consider using the thin wall tube for diagonal braces, or building a storage shelf under the MM, rather than primary structure. If you have any flex in the thin wall you will need to add extra diagonals.
I suggest you practice your welding first rather than learn on such a nice machine as a MM.
David
Old Wed 13 March 2013, 03:57
Andrew_standen
Dorset
Good Point on the thin wall.
Welding will be fun to try.
Andrew
Old Thu 14 March 2013, 15:10
Andrew_standen
Dorset
Steel arrived today.
Not used metal before. very dirty stuff ! lol.
As my materials had to be cut from 7.5mtr lengths, I now have the off cuts.
So, I have a lot of 100 x 50 x 3mm left over, I will use that for legs.
57 legs turned Can do orders for others sailfl The Market Place 24 Mon 10 January 2011 10:10
Strong Math Person sailfl General - MM Build 10 Wed 10 February 2010 10:17
Legs - their purpose and sizing (Can legs be bolted......?) Gerald D 10. Base Table 0 Mon 20 April 2009 23:50
Table legs for storing sheets underneath vadeem 10. Base Table 2 Fri 01 December 2006 00:26
