#1
going for a 4x4 table build
Afternoon folks,
I'm building a 4x4 cnc at the moment, mostly to cut foam. Due to budget am using t5 belt and tensioners for X axis, possibly also for Y. My question is really about the z axis. On MYCNCUK forum i'm persuaded NOT to use rack and pinion for the Z axis but ballscrew instead. I can see it may have a greater resolution but I see that folk at Mechmate forum are using rack and pinion for Z. R&P is cheaper, any reason why not to use it? Any thoughts greatly received ![]() |
#2
Hi there,
just posted a question about about R&P versus ballscrew on the z slide part of the forum. I'm making a 4x4 table with a drop centred table to do deep axis cutting of foam and light materials. Using vgroove bearings and steel strip for linears, t5 belt drives for x and y axis 4 x nema 24 and gecko 540 linux and Mach software. Have a workshop and not bad at making things work, looking forward to getting the cnc started and working. Not as yet got Mechmate plans but I like its flexibilty a lot and as i'm also using mild steel for everything its similar. Onwards... |
#3
Welcome to the team !!!
#4
Hi I know from my current situation (building at the moment) that i am going with R&P because i have it left over form the other axis (it will cost nothing) and it seems to work
i can''t think of any reason not to use it. If your worried about resolution add a belt reduction to it later your MM can help you with that![]() |
#5
I personally have used a 48" long z-slide with a proper counter balance assembly driven by an OM 7.2:1 Nema 34 motor on my MM for foam cutting. Never an issue with R&P - ever.
Visit MM #5 in the #400 post part of the thread for pictures. http://www.mechmate.com/forums/showt...&postcount=471 http://www.mechmate.com/forums/showt...&postcount=446 Last edited by smreish; Thu 10 January 2013 at 20:58.. |
| Build starting in Huddersfield UK November 2012 **table alterations & long Z axis** | mattmurphy | Introduce yourself and start planning | 3 | Thu 15 November 2012 06:36 |
