#1
Motors
How well will the motor be with a G540?
3.3 N·m, 86 mm (470 oz·in, NEMA 34) Stepper Motor motor Holding Torque (Series Wiring) 3.3 N·m (470 oz·in) Amps/Phase (Series Wiring) 3.0 A Resistance 0.8 Ω Inductance 3.5 mH Rotor Inertia 1400 g·cm² Length 80 mm Weight 2.3Kg Leads/Wires (Color Coded) 8 Shaft Type 12.7 mm, Flat Step Angle 1.8 ° Stepping Accuracy 5% Temperature Rise 80 °C Max Ambient Temperature -20 °C to +50 °C Insulation Resistance 100 MΩMin 500 VDC Dielectric Strength 500 VAC 1 Minute Maximum Radial Load 0.06 mm (450 g) Maximum Thrust Load 0.08 mm |
#2
Looks like a very good match.
| Stepper motors giving trouble - Motors burnt while serving as ground for elec. fault | Daya | Troubleshooting | 45 | Mon 21 April 2008 01:05 |
