Old Mon 19 November 2012, 04:28
bobhome
Just call me: bob
bristol
Pre purchase questions and hello
Bob here from the UK, hello everyone.
Been looking over designs for an 8 x 4 sheet capacity cutting CNC router for sometime. Tried designing my own, but feel that I would probably waste more money this way. Really like the look of the Mechmate and the bonus of having a tried and tested system that has years of development behind it.
So, Mechmate it is.
Just a couple of questions regarding the design before I purchase the plans:
1. How has the design evolved over the years?
2. Is there a changelog?
3. How critical are the metal frame dimensions (assuming some sizes in the UK may not be readily available)
4. What dimensions are absolutely critical to the correct operation?
5. Can the laser cut parts be bought in the UK?
6. Is it possible to fit a standard router/another router to the Mechmate
Bob
Old Mon 19 November 2012, 10:16
1. The base design has changed very little. Improvements to ease fabrication, increase compatibility with different choices of motor or rails, or incorporate small tweaks from the field have been added. None of these have been major.
2. The original diagram set indicates last change dates; there have not been recent changes. Areas of experimentation are generally in the threads here on the forum.
3. A wide variety of structural steel shapes have been used successfully all over the industrialized world. You will be able to find something that works.
4. Almost none, as long as the replacement is sufficiently equivalent in function. However, craftsmanship in preparing and aligning the rails is important.
5. Pretty sure they have been. Look here: http://www.mechmate.com/forums/forumdisplay.php?f=70
6. Yes.
New Member has Questions hevertg Introduce yourself and start planning 22 Sat 09 June 2012 16:43
M2-M6 Drawing Questions Tom Ayres General - MM Build 2 Thu 31 May 2012 17:11
New Member with Questions BSims66173 Introduce yourself and start planning 2 Thu 03 November 2011 11:51
Before I buy could you guys please check my purchase Regnar 702. Power Supplies 2 Mon 18 January 2010 21:31
Do not purchase Vacuum application drives from Geckodrive kn6398 701. Motor Drives 2 Fri 14 November 2008 20:57
