Old Sat 10 November 2012, 05:27
ModBus 101
It has come the time for me to have a go at the ModBus thingy in Mach3.
Done my Google on the subject & hours of staring at the screen reading documents written in Sanskrit...
Would most appreciate if anyone could give me a jump start by explaining the followings terms in plain English?
Coil
Descrete Input
Holding Reg
Input Reg
Single Coil
Single Reg
Million thanks in advance.
Old Sat 10 November 2012, 20:06
zumergido
Just call me: Fernando
BS AS
i have made a modbus,
coil its output like relays or other on off thing.
discrete input can be 0 or 5v input depends on the electronics. on off thing.
Holding Reg can have a value of 0 to 255 . usefull for pwm of control vfd driver
Input Reg its a 0-255 input. like potentiometer or voltage reading.
on mach3 this uses brains control.
you have some videos here http://www.machsupport.com/videos.php
i have this controller
7 relays
10 digital inputs
1 pwm output
1 mpg input
3 analogical input.
works on serial rs232 i have some interference problems that i have to fix. beside that works great.
on the web you can find network modules, serial, rs485. all work the same.
Old Sat 10 November 2012, 20:39
Hi Fernanda,
Thanks for the heads up. Helps a lot!
Q's
When you say pwm out put, do you mean frequency output or Analog Voltage using PWM.
Arduino Modbus danilom 70. Control Systems 3 Sun 19 May 2013 21:54
Hitachi SJ200 and ModBus Control Problems skippy Troubleshooting 3 Wed 19 January 2011 04:03
