Old Fri 28 September 2012, 17:40
toad
Just call me: Toad #80
Burlington NC
Assistance on 4th axes setup
Wayne #25
I am trying to get a 4th axes setup, Presently I have as described,
A axes slaved to B
Set up A axes,
A and B enabled (Why B?) step 2 port 2
Toolpath
Axes of rotation
X checked
A rotation enabled checked
Show lathe objects checked
What am I missing? What on the keyboard jogs A axes?
Good info, but I am still lost. Can you anyone else assist further.
Where can I find more info.
Toad
Old Sat 29 September 2012, 00:13
Why is A slaved to B - Its usually X slaved to A
Why are you using port 2, do you have two ports and two BOB's, if not, they should be set to: step1, port1
X-Axis is usually down the length of the machine and if you have two motors then another axis is slaved to it (a 3 axis machine would slave A, on a four axis machine I would slave B - On the general logic config tab, uncheck "B axis is angular")
Y-Axis is usually across the width of the machine.
Z-Axis is vertical from the table
A-Axis is usually rotational on its own
These settings also need to correspond to the correct settings on the ports and pins - motor outputs tab.
Old Sat 29 September 2012, 08:24
toad
Burlington NC
4th axes.
Alan,
Thanks, I was mainly going by what wayne had set up. H must have 2 bobs.
I was having a hard tim getting my arms arouns B also and port 2.
So there is no key to move A, does everything else look ok?
Toad
Old Sat 29 September 2012, 09:42
Try += and -_ (the two keys next to "Backspace")
PMDX 126 BOB Setup MetalHead 70. Control Systems 21 Sat 17 August 2013 22:26
Static and dynamic loads on the axes jwt Rails & Rollers 1 Sun 10 October 2010 17:11
Assistance needed moving from router to spindle miketeejay Miscellaneous / General / Whatever / Catchall 1 Thu 12 August 2010 11:30
Happy to watch the axes mooove AND cut wood! - Abbotsford, BC, Canada fredkehler MechMates already cutting 32 Fri 23 April 2010 09:58
M110110M Angle iron rails for X and Y axes Gerald_D Rails & Rollers 69 Sat 15 September 2007 17:17
