Old Sun 19 August 2012, 18:23
JasonC
Just call me: Jason
Soldotna,AK
spindle source
Does anyone know of a source for a Delta 3.7KW (single phase)220v VFD
I keep hitting dead ends
Jason
Old Sun 19 August 2012, 20:54
That would tend to be an unusual configuration. Could you use a 5.5KW three phase fed with the single phase instead? And you realize that such a device would be looking for something on the order of a 35A input?
From what I can see, such a model isn't available as a VFD-A, VFD-EL, VFD-E, VFD-M, VFD-F, VFD-B, VFD-VE, or VFD-C2000 series from Delta. Are you sure this exists? AFAIK, single phase VFDs cap out at 2.2KW / 3HP, and beyond that you have to use an oversized three phase unit.
Old Sun 19 August 2012, 21:00
JasonC
Just call me: Jason
Soldotna,AK
All I have is single phase where I live and want to have the largest spindle unit I can get.
Im getting a 3.7KW spindle.
Old Mon 20 August 2012, 06:35
Then you should definitely look at getting an oversized VFD - 2X the size if you're actually going to run that spindle hard. See here and search for "3 phase vfd on single phase" for other information sources. You can also comparison shop VFDs from Hitachi and Teco if you aren't 100% locked on Delta. If you ask a rep from any of the three companies they can help you size for your needs.
Old Mon 20 August 2012, 08:10
JasonC
Just call me: Jason
Soldotna,AK
Thank you Bradm, I didnt know that was possible. I love options.
Jason
Old Mon 20 August 2012, 08:25
Jason,
The one below is a 3hp single or 3 phase input. If you read the manual you will see the HP rating derated to about 1.75 HP. I haven't seen any 1/3 phase input larger than 5hp lately, thus leaving you about 3 HP readily available on a 1 phase input.
Something like this:
http://www.automationdirect.com/adc/...AC%29/GS2-23P0
Old Mon 20 August 2012, 09:40
PEU
Just call me: Pablo
Buenos Aires
(Hola Sean!)
Some months ago I saw a VFD for a 5HP motor (3.7kw) that was 3/3 phases but it could work also with one phase missing, the current consumption doubles when this happen.
I agree, for single phase input, 2.2KW is the usual ceiling
Pablo
Old Mon 20 August 2012, 10:46
This appears to meet your specifications. Can't vouch for the manufacturer though. I was trying to find a manufacturer that still makes a VFD where the manual states that it will operate with a missing phase (or can be overridden). That used to be common, but I don't see it in the latest drives - they seem to have gotten too smart for this usage. Again, I'd call a rep (or vendor) or two.
Old Tue 21 August 2012, 06:16
Belli
Just call me: Greg
Johannesburg
Hi Jason
A Yaskawa V1000 is rated at 4kW, 220V single phase input (the biggest single phase that I know of), we have used buckets of them on HF spindles.
Old Tue 21 August 2012, 08:03
...and the Yasakawa is well supported here in the States too.
Old Tue 21 August 2012, 08:19
JasonC
Just call me: Jason
Soldotna,AK
I found one that will handle what Im looking for.
http://www.pdscolombo.com/prod_vfd.php
Thanks for the help everyone.
Jason
Old Tue 21 August 2012, 08:40
I have been a little slow on this thread.
But take a look at this inverter as well. You may also want to give them a call and tell them what your doing with it. One of the key factors is to make sure you can run a 400hz otherwise you will only get half speed out of the spindle.
http://www.factorymation.com/s.nl/it...category=15367
$299.00 plus shipping
Old Tue 21 August 2012, 17:52
Ratings: 1/8 to 5 HP at 240 VAC 1-ph, for Yaskawa V1000 so its 3.7kw not 4 but that's the value Jason wanted.
The Delta single phase biggest is 022 , or 2.2kw on the link you posted Jason?
The question is... do you have a 3.7kw 5HP , 24000 rpm 220V SPINDLE?
This combination will cost, do you have a specific reason or application behind this?
I know that my 2.2kw spindle is enough as I rarely see load on the vfd above 50% (6mm bit, 9mm doc in ply-wood = 26% load)
(35mm ogee bit, MDF 6mm doc, 55% load)
Only reason for me wanting the 3kw one is because is because its larger and more robust.
Old Tue 21 August 2012, 22:00
Constant speed spindles are expensive. Most low cost spindle in the market are constant torque spindle, they slow down when you feed them too fast. This will cause some issue with some cases when you really need constant cutting speed. Over sizing the spindle & use only a fraction of the spindle capacity will help maintain a more constant cutting speed range.
But really, 2.2kW is good for most cutting. I use 3Kw because I need to do texture carving with 25mm radius ball nose bits with cutting depth varying between 1 to 6mm constantly. with a 2.2kw, the spindle works into 80% of the spindle capacity & you can hear the spindle slowing down on deep cuts & speed up at shallow ones. Also it will trip the invertor when the bit get too blunt.
Old Wed 22 August 2012, 08:56
JasonC
Just call me: Jason
Soldotna,AK
Thanks for the info everyone. With all the funds I have saved doing this project myself vs buying one I have a good amount of funds and wanted a spindle that wouldnt be the weak link in the machine. A big concern of mine is carving and hitting hardwood knots. I also have a 50 amp breaker for the spindle.
Jason
Old Wed 22 August 2012, 11:57
timberlinemd
Just call me: Steve #66
Arizona
I don't want to hijack this thread, but when I get my spindel I intended to use my 10hp/3p rotary phase converter (220v/1p input) as the primary input to the VFD for the spindel. Has anyone had any experiance with this kind of setup or can offer any feedback?
Old Wed 22 August 2012, 12:04
Jason, that pdscolumbo page you linked to clearly shows that the single phase Delta B VFDs cap out at 2.2kw / 3 hp (see the 3rd row from the bottom in the 230 V section).
Danilo noted this as well.
If you look at the manual for the Teco 7300CV that Mike posted, it also clearly shows that the single phase model caps out at 2.2kw / 3 hp.
So the Yaskawa and the Polyspede are the only two thus far that state support for 5 hp on 1 phase. (I'd choose the Yaskawa).
Old Thu 23 August 2012, 10:24
JasonC
Just call me: Jason
Soldotna,AK
Yaskawa looks good. Anybody using one of those and have any feedback?
Yaskawa V1000 CIMR-VUBA0018FAA
Jason
Old Sun 26 August 2012, 11:20
zumergido
Just call me: Fernando
BS AS
besides the hunger for hp on the spindles. remember to keep in mind how many amps you have. in my country 25 amps 220v its the average. so if i get a 5 hp machine i will use 17 amps "in a perfect world" and leaves 8 amps for lights and other apliances.
Old Sun 26 August 2012, 14:41
JasonC
Just call me: Jason
Soldotna,AK
I have 200 amp house feed.
Jason
Old Thu 29 November 2012, 22:10
Jason,
What did you ever decide?
Old Thu 29 November 2012, 22:28
JasonC
Just call me: Jason
Soldotna,AK
Went with Dale Walshs setup. That thing is a beast! But I have been buried in work and havent had a minute of time. He gives you top notch service!
Jason
Old Sat 12 January 2013, 20:55
JamesJ
Kansas
Jason
Please share Dale Walsh website as I am shopping for a spindle. Thanks.
Old Sun 13 January 2013, 09:35
JasonC
Just call me: Jason
Soldotna,AK
Dale Walsh doesnt have a website, PM him.
Extremely high level of service and quality!
Jason
Open Source Vector Graphics Surfcnc Golden Resources 0 Sun 06 March 2011 04:42
Source for timing pulleys DTGuitars Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 4 Tue 05 October 2010 07:39
Desperate for a new tape source iqchallenged Golden Resources 3 Sun 21 March 2010 11:34
Source for laser cut parts Medemt General - MM Build 1 Sun 29 March 2009 18:08
