Old Tue 24 July 2012, 15:11
Mrayhursh
Just call me: Hurshy
Riverview, Florida
Picture of Control Box
I am in the process of building the control box. I purchased the elctrical box that CV supply sells. fyi...unless you have access to a great parts store in your area this is a great way to start your project. I also talked to the techs at PMDX and the recommended the pmdx-126 to go with the Gecko G203v stepper drives.
They also recommended the PMDX-134 motherboard to hold the G203v stepper drives. Does any have any pictures they can show to help me organize these parts. Also is anyone using connectors to connect the stepper motors to the control box. Mike alias Metalhead has recommended the philosphy that connectors introduce another point of failure. Let me know your feelings.
Old Tue 24 July 2012, 21:25
http://www.mechmate.com/forums/showt...14&postcount=1
Look here. It is of the 133 board, but the hook up is the same for the 134.
Old Thu 15 August 2013, 20:03
Mrayhursh
Riverview, Florida
PMDX circuitry
In the PMDX-134 manual it states "NOTE - We recommend that the AC mains input to your power supply be fused. We recommend against having switches in the DC connection from your power supply to the PMDX-134."
What are we using as a fuse for the AC input?
Old Fri 16 August 2013, 07:21
I used the dedicated breaker from the fuse panel as my protection in front of the disconnect.
Old Fri 16 August 2013, 08:36
Mrayhursh
Riverview, Florida
on the http://www.mechmate.com/forums/showt...14&postcount=1 link
there is a pic of the PMDX-134. The small black terminal has a wire I suspect it is a resistor coming out of the terminals. I checked both the PMDX-134 and PMDX-126 manuals. I found several spots mentioning a pull up resistor but no mention of the resistor ohm value. Is this something I need to add?
zsurf4 from picture to 3d normand blais Utility software 0 Mon 21 January 2008 07:25
Test picture upload Gerald_D Test Area for this forum 10 Fri 02 March 2007 12:07
