Old Mon 23 July 2012, 13:30
andrewuk
Just call me: Andrew
leeds
Relays
Hi has anyone used one of these relay boards with their proximity sensors or got thoughts/ advice on them, just finishing the shopping list and then ill make a start putting it all together. Thanks
http://www.ebay.com/itm/12V-4-Channe...#ht_4202wt_934
Old Mon 23 July 2012, 19:29
I'm a little confused here. If I understand that board correctly, it's for outputs - you provide 12v to operate the relays, and a signal from a microprocessor can switch them - the output stage can support 120-240v, up to 10A.
Since the proxys are inputs to the computer, I don't understand how this board would apply. Did I miss something?
Old Mon 23 July 2012, 22:06
Red_boards
Just call me: Red #91
Melbourne
Depending on your BOB and sensors you may not need relays at all. I don't have any with the PMDX125
Old Tue 24 July 2012, 13:00
andrewuk
leeds
relay board
Thanks both of you for the replies,thought i had the right board but looks like i need to carry on looking, any ideas where i can get a board as Gerald describes in earlier posts. Thanks
Old Tue 24 July 2012, 13:03
What BOB are you using?
Old Tue 24 July 2012, 13:25
andrewuk
leeds
breakout board
Hi mike its this one from a uk supplier http://www.diycnc.co.uk/html/uniport.html
General wiring, supply voltages, relays, E-stop considerations jhiggins7 70. Control Systems 24 Sat 13 March 2010 02:01
why do relays get hot javeria Miscellaneous / General / Whatever / Catchall 4 Sun 08 February 2009 02:28
