Old Tue 26 June 2012, 08:38
Kart
Just call me: Kart
Texas
pmdx 133 fried
2 boards same place. These are at the x and slave motors. PMDX thinks it might be a part failure. Anybody else seen this? Comments?
Old Tue 26 June 2012, 09:15
If your motors hadn't turned before, and the burn happened at first attempt to power motors, then I think your motor wiring is incorrect and something had to give.
Did you unplug the green connectors off the board? If you do this too many times, the friction grip loosens and could start a burn point.
Old Tue 26 June 2012, 09:48
Lots of dust... fire hazard
the wires look like they'r cooked, so it must have been some "short". Do drives still work?
might been that they put out some voltage across those wires
Old Tue 26 June 2012, 09:53
How are your motors wired at the other end of the cables?
http://www.mechmate.com/forums/showt...14&postcount=1
This shows the pairing for parallel configuration. (Of course this is during the table project and your pairs will be out on the end of your wires at the motors.)
Also I agree you need to check for a short somewhere in the wiring.
What part number wiring is that?
Old Tue 26 June 2012, 09:56
oh.. haven't seen that its a Motherboard for Geckodrive. That those are the wires directly to the motors. Something really wrong happened here
Old Wed 27 June 2012, 04:58
southernduckie
Just call me: Andrew (Duckie)
new south wales
133 wiring
huge current there, are there any other motors hooked up and working? please give us more info like, power supply, motors, when it happened first power on or during use? open the drive and see if there is any damage visible. might give clues
Old Wed 27 June 2012, 07:30
Unless the PMDX-133 was defective, it looks to me like a wiring error occurred. The wiring diagram (Table 2 in section 3.1 of the PMDX-133 manual) shows how to connect the wiring for the A, /A, B and /B connections to the Gecko stepper drives.
To get enough current to produce the kind of heat that caused that much damage means that a short occurred somewhere. I cannot imagine that Steve at PMDX would not have tested his products before shipping, especially something as obvious as a dead short between terminals. It could happen, but I've never seen that kind of error escaping quality control.
Old Sun 19 August 2012, 13:18
JasonC
Just call me: Jason
Soldotna,AK
Get the multimeter out and see whats going on.
PMDX 126 BOB Setup MetalHead 70. Control Systems 21 Sat 17 August 2013 22:26
Pmdx-122 sold! IN-WondeR The Market Place 6 Thu 03 January 2013 19:39
New PMDX-126 Dale Murray General - MM Build 5 Tue 17 May 2011 19:44
PMDX-122 vs PMDX-125? salewis 70. Control Systems 6 Fri 06 November 2009 05:16
PMDX-132 instead of the PMDX-122 SteveWellman999 70. Control Systems 23 Mon 02 November 2009 11:47
