Old Sun 27 May 2012, 01:41
JasonC
Just call me: Jason
Soldotna,AK
Basic question
Im building a cnc router...Has anyone made a multi use mechmate. Say adding a removable tray on the table for a Router/Plasma cutter?
Jason
Old Sun 27 May 2012, 02:55
Quadro
Just call me: Anthony #77
South Australia
Yes, it works but..... the change over time is a killer. It took me 2-3hrs to change over, even with 2 blokes 1.5hrs. After the second time I had enough, each 2 hours could be spent making another MM not to mention lost productivity so I am in the process of building another.
I thought it would be easy but I have now put it down to a bad idea .
Old Sun 27 May 2012, 05:09
Jason
#58 is designed and performs this duty. It is really a dedicated Plasma machine, that when needed for quick other routing work, you add a spoilboard, resurface and start cutting.
I agree with Quadro, the change over time is significant. Mixing fire with wood requires a bit of planning and diligence.
Old Wed 30 May 2012, 08:48
JasonC
Just call me: Jason
Soldotna,AK
Was thinking more about having it set up like a duel router or spindle setup.To keep the changing over part as minimal as poss. Rather than a complete re-set up. Ill look at #58.
Thank you
Jason
Old Wed 30 May 2012, 08:51
JasonC
Just call me: Jason
Soldotna,AK
the search isnt showing #58 does anyone have a link?
Jas
The only reason is I do allot of both anduntil funds permit Im trying to use what I have.
Old Wed 30 May 2012, 10:51
Axel1966
Just call me: Axel
Paris
France
MechMateForum > Personal Build Histories > MechMate Already Cutting > Page 1 :
MechTorch! The First Mechmate Plasma #58 - Winston-Salem, US
Old Wed 30 May 2012, 17:18
Quadro
South Australia
You will also have to think about dust management from the router and plasma.
You will run out of inputs/outputs on one BOB, so a second BOB and a second parallel port PCI card wll be needed.
2 configs/setups for the controller software could be needed.
I'm no trying to put you off or tell you it can't be done, just making sure you had thought of everything.
Old Thu 31 May 2012, 08:58
JasonC
Just call me: Jason
Soldotna,AK
Ok thanks, i have the dust management under control now...I have a full machine shop here at home.
Im currently setup with the router side using USB.
I havent had time to research all the control side yet. it should be pretty close to the router except the touch sensor, the plasma torch trigger and amperage device..?.
Anyone have a basic controler blueprint from the power supply out for a plasma setup? Or maybe a link.
I may just end up doing a straight plasma cutter and have the funds generated from that fund the cnc router...oh and a shop extension..lol.
Jason
Old Thu 31 May 2012, 14:56
Axel1966
Just call me: Axel
Paris
France
May we have a photo of your router ?
Old Thu 31 May 2012, 19:49
JasonC
Just call me: Jason
Soldotna,AK
Im not finished but the base is complete and the controler tested, waiting on .083x2x4 steel from the states. None in alaska...lol.
Old Thu 31 May 2012, 20:50
JasonC
Just call me: Jason
Soldotna,AK
Is having the plasma added as...lol...simple as adding a THC to the controller? I have a pmdx-126 bob. I read the importantance of isolating also.
Jas
Old Thu 31 May 2012, 22:07
Jason,
Others have successfully used 3/16" and 1/4" wall tube for the Y axis gantries. Can you get that locally?
Old Fri 01 June 2012, 05:50
Quadro
South Australia
To connect a plasma with a digital THC you will need the following -
Arc On (connected to plasma - output on BOB)
Arc Ok (connected to plasma - input on BOB)
Torch Down (connected to THC -input on BOB)
Torch in Position (connected to THC - input on BOB)
Torch up (connected to THC - input on BOB)
Torch Touch off (connected to THC - input on BOB).
With that many THCs and BOBs you will have to make sure they are comaptable.
I would stick with the 2mm RHS if it is for a plasma - aceleration is most important.
Old Fri 01 June 2012, 08:22
JasonC
Just call me: Jason
Soldotna,AK
Thats great info thanks.
Im looking at the LCTHC at CandCnC.
Jason
Old Fri 01 June 2012, 10:49
Anthony, what purpose serves the IN POSITION input? I use Agelkom THC and have not used of this input, up/down is all that works for me besides the touch and set height. Thanks
Old Fri 01 June 2012, 16:41
Quadro
South Australia
Danilo, your right as far as controlling the z axis In position has none. It can be used for an on screen indicator.
Basic Cutting Tutorial Doug_Ford General - MM Operating 27 Sat 20 August 2016 04:42
Basic schematic of a typical CNC control box Gerald_D 70. Control Systems 14 Sat 06 July 2013 14:10
Basic laser part set for sale Rypper The Market Place 4 Sat 19 March 2011 07:26
I have a question saas Introduce yourself and start planning 6 Thu 10 September 2009 07:36
Basic theory of vacuum holddown & pumps Gerald D 10. Base Table 2 Mon 21 April 2008 05:00
