Old Fri 30 December 2011, 11:55
WTI
Just call me: James
Detroit (Michigan)
Mechmate difference from 2006
Way back in 2006 I had the laser cut parts made and they have been sitting on a pallet at the top of my rack.
Fast forward to March of 2012 and I may actually be so far ahead of production that I might indeed have time to put my Mechmate together.
Any critical changes that came with the newer "Mamba" version that I should be aware of?
I seem to remember that there were some E-chain changes...anything else?
Old Fri 30 December 2011, 12:46
James,
The key differences that I can remember (since I have built machines with both parts)
- No y-car Cable chain attachment for the x axis chain.
- No x-axis cable chain supports
- Motor plates are most likely the "universal type" and they work perfectly for any scenario.
- The spider for the z axis will most likely only have markings for 4 bearings, not the 6 as noted in the Mamba set. BUT, a little extra layout and you will be able to locate those and add them for the extended option.
- the proximity sensor hole on the y-car may have to be enlarged
- the spring hold down location for the z-axis motor may or may not be marked/drilled on the y-car
- The y-car side plates are handed and must be located on the correct side of the car.
- the "skate" may or may not be included in your laser set depending on the date you had your parts issued.
...that's about all I can remember about now.
All of the notations are very simple changes and won't require any real difference in the build.
Old Fri 30 December 2011, 13:45
WTI
Just call me: James
Detroit (Michigan)
Thank you Sean!
I'm OK with no skate, as I found a machine shop with a Horizontal Mill. That is a machine that was born to make rails all day long. I'm making a few extra lengths and putting them away for future replacements.
Old Fri 30 December 2011, 14:57
revved_up
Just call me: Craig
Hartland, MI
James, care to share the name of the shop you found. every shop I talked to said that they're mills could only cut 18" at a time and would be unable to get a consistant edge the full length.
Old Fri 30 December 2011, 15:07
WTI
Just call me: James
Detroit (Michigan)
Craig, I think the shop is called X-type, it's a prototype shop that a friend works at.
Indeed, he said his horizontal mill only has 48" of travel, but he said that the overlap joints will be better than the mill scale on the bottom of the rails.
PM me your phone number if you want him to run some rails for you at the same time. I'm sure the more rails we make, the better the price will be.
Old Fri 30 December 2011, 15:11
I can hook you up with most of the parts changes.
Old Fri 30 December 2011, 23:09
The old motor plates were for a rail height of 25mm if I recall correctly.
Old Mon 06 February 2012, 13:56
WTI
Just call me: James
Detroit (Michigan)
Would we need to make new motor plates for the difference?
Or just weld and re drill the old ones?
Old Mon 06 February 2012, 17:29
If you use a 20T pinion the old plates work with the Mamba rail height.
The 30T to 35T pinions don't swing far enough out of the way or allow engagement.
I used the 20T pinions with the universal plates and Gearmotor without an issues with the new rail height. I was the Guinea pig.
Old Mon 06 February 2012, 18:36
What motors are you using? I have extra motor plates.
Old Mon 06 February 2012, 19:41
WTI
Just call me: James
Detroit (Michigan)
We have the OM geared 7.2s with the Boston Gear YA30 pinions.
Old Mon 06 February 2012, 20:39
I can hook you up with a set of motor plates no problem. I'll PM you
Old Tue 07 February 2012, 01:50
DocTanner
Just call me: Don Ross
Blue Ridge, Texas
The original motor plates work well with the old rail height. I use the OM 7.2 and 30 tooth pinion.
Old Tue 07 February 2012, 06:19
Don! You are making a rare appearance here - nice to see you again!
For the rest who don't know Don, he was the first guy to get his own MM cutting, and would have had #1 if he had wanted it.
Old Tue 07 February 2012, 06:55
Don!
Rare appearance indeed. So good to see you sir!
Old Tue 07 February 2012, 12:32
revved_up
Just call me: Craig
Hartland, MI
Fabrica and Don in the same week. going to have to start an alumni reunion thread soon.
pinion gearing and difference in sizes Gabriel Rails & Rollers 4 Wed 18 May 2011 14:19
Air cooled vs Water cooled spindles - what is the difference? chopper 50. Toolheads 4 Mon 16 August 2010 11:58
ProgeCAD LT 2006 free for personal use Gerald_D Graphics & CAD 15 Tue 15 January 2008 17:22
What's the difference between Home and Limit switches? Marc Shlaes 70. Control Systems 6 Tue 19 June 2007 07:46
