Old Wed 16 November 2011, 19:11
Drive tension spring too tight?
Recently a thread discussed using rubber bands, zip ties or what ever else to tension the MechMate drive motors to the rack. This had me think that "what if it's too tight" ? What if the motors have too much direct tooth pressure and not enough movement within the engagement to "find a comfortable mesh".
I visited a machine locally that had begun to show signs of chatter and restriction of movement on the x/y change during curve and circle cutting. This is usually the sign of the everything beginning to loosen up. A grub screw, a bearing hold-down, a motor pivot shaft - something. This machine was what appeared perfect.
What I found was the machine, over time, actually tightened up some, and was restricting the gentle (built in the design) anti-backlash performance of the machine. What we found was that the too tight spring, the slightly tight adjustment bolt/nut on the swing plate and the slightly to snug motor pivot point caused the machine to make noise, shutter on transition and expose inaccuracies.
Moral of the story....sometimes loose is good.
Old Wed 16 November 2011, 22:49
Like a happy tappet on a V-8
Old Sat 19 November 2011, 04:39
It was my machine and the difference in springs and removing the plastic washers helped in the performance of my machine.
Thanks again Sean.
Old Mon 05 March 2018, 12:42
IamDave
Just call me: Davey
Ball Ground, GA
I think I just experienced this. Springs to tight cause chattering and racking.
Old Fri 09 March 2018, 13:20
ifffff
Just call me: Ivo #38 & #130
Parnu
Estonia
Well.... intresting. I have on my MM drive tension springs taken from car drum brake pads. And for installing installing them i need lock pliers and lots of force. And i changed weaker springs for them because of chattering...
Old Fri 09 March 2018, 17:29
IamDave
Just call me: Davey
Ball Ground, GA
I loosened my springs and it helped greatly with the racking problem. My speed setting was way to high as well. Now it moves smoothly.
Breaking drive belts - getting the right tension. . . . . javeria Troubleshooting 17 Thu 17 October 2013 04:00
Mounting the cables in the cablechain – fairly loose or tight up ? Barman 60. Wiring & Cable Management 15 Tue 26 April 2011 17:54
Slaving a motor - put its drive in parallel to another drive on the same BOB output J.R. Hatcher 70. Control Systems 34 Mon 16 November 2009 09:13
Gas Spring : Compatible automotive gas spring Nikonauts 40. Z-Slide 0 Sat 03 January 2009 09:59
Spring tension adjustment - is it needed? drieslaas Motors & their mountings 5 Sun 25 May 2008 19:54
