Old Wed 21 September 2011, 09:06
Compression spiral LEFT hand bits
Anyone ever used left hand bits?
Would there be a problem with nut going loose from cutting in opposite direction?
I found some really nice compression bits but are left handed. as I plan to cut in one pass with them there would be a lot of force.
Spinning the spindle in ccw direction is no problem with VFD.
Got a lot of orders for cutting laminated chipboard (melamine both sides) and as I could not make the perfect cut with either straight bit or spiral had to turn them down.
Saw some advice about using two bits, down and up spiral one after another, but how well it would end up, a little of backlash or something and you got a ruined 50$ board
Old Wed 21 September 2011, 10:08
You can use a compression spiral for that job. It has upcut on bottom of bit profile and downcut on the top. You have to cut in a single pass for it to work, but you were going to do that anyway.
Copmression Bits from Centurian Tools
These are an example from around here. You should be able to find them in your neck of the woods as well.
Old Wed 21 September 2011, 10:12
A compression bit is typical for the doublesided cutting your require. If you want to do a tool change, you can use a standard bit to cut the material in a few passes to clear the part, then use the compression bit to cut a FULL height pass, removing a very small amount of material for a finished chip free reveal. This is best done with a vac holddown, but can be done with tabs and such if needed.
Summary, if you have a 4" x 4" part, you over cut the part to 4.1" x 4.1" with a standard (cheap) bit with as many passes as required for speed, then use the compression cutter to finalize the 4" x 4" part at an optimized rate
Good luck
Old Wed 21 September 2011, 10:14
My question is mainly concerning the :
as the tool I found is to be spin in CCW direction
Old Wed 21 September 2011, 10:17
I have not cut anything with a ccw bit before. Cannot say I have even seen any for sale. Guess I didnt read the post clearly.
Old Wed 21 September 2011, 10:23
I think you will be okay to cut left-hand (spindle running opposite to normal). The nuts of the spindle do not carry the torque, they are just locking nuts.
In the 60's, a lot of cars had their left side wheels attached with left hand screws, but they don't bother with this today. (Chrysler, VW Beetle I remember in particular)
Old Wed 21 September 2011, 10:31
My father wouldn't let me touch the BMW's and Merc's at that age, but they also had left threads on the left wheels.
Old Wed 21 September 2011, 11:06
I miss understood your question. I have a Bridgeport mill with an ER-20 collet that is right threaded. I run it both in CW and CCW all the time with left and right spiraled bits. I haven't found an issue with it unlocking. Of course, I am running at 100 to 3600 RPM, not 12,000 to 24000 RPM.
Old Wed 21 September 2011, 14:05
We will see. will get back to you with results once the bits arrive to me.
Old Wed 21 September 2011, 17:25
ger21
Just call me: Ger
Detroit, MI
When we use LH bits in an ATC spindle, we use left handed tool holders with left handed threads. If they weren't needed, then they wouldn't make em.
Old Thu 22 September 2011, 00:24
Ger, we know that people make them, and probably charge a premium for them, but have you seen one come loose when it goes the wrong way? Sometimes people make them because they can
What is Danilom's risk if he does some experimenting in this area? Cutter stops spinning while machine continues to try and move.......we have have other things that can also cause that, but it doesn't prevent us from actually using our machines.
With the HSD spindles that we have, the main bearing retainer is held in with a left-handed nut. If the bearing seizes then it will tend to tighten the nut. HSD does sell CCW rotating spindles and I guess they change the direction of this thread. But I can't recall offhand having seen LeftHand collet nuts anywhere and I wonder if the collets ever go LH?
Old Sat 24 September 2011, 20:04
ger21
Just call me: Ger
Detroit, MI
I've never used one, so can't answer that.
The toolholders I mentioned have LH nuts on them. The nut is what makes them left handed.
These toolholders use ball bearing nuts which allow both LH AND RH operation. I've never seen one, though.
As you said, worst case is that the bit comes loose. It would probably break if it stops spinning. I guess if it does come loose, it's possible that the nut could unscrew and the nut and collet could fly out??
Old Sun 25 September 2011, 01:10
I once had a bad experience with a nut coming loose (but it wasn't a spindle)
It was a handheld angle grinder with a fancy braking system that stopped the motor as soon as the trigger was released. Sounds good in principle, but with a heavy tipped blade in there, the inertia of the blade wheel kept it spinning and loosening the nut.....then the blade would spin for about 10 seconds behind the nut while I prayed that the nut wouldn't come right off the shaft .
Finished and first job done! - Deurne, Antwerp, Belgium BartDeckers MechMates already cutting 43 Mon 02 January 2012 01:05
Can the X,Y zero be moved from right to left front? Hans 10. Base Table 9 Wed 08 June 2011 22:34
Bits ... the selection of bits, truth, myth, etc. silverdog Cutting various materials - bit selection, feeds, speeds 8 Sat 04 December 2010 22:32
Up Spiral Bits PEU Cutting various materials - bit selection, feeds, speeds 24 Sat 27 March 2010 11:04
