Old Mon 04 July 2011, 14:46
giggler
Just call me: giggler
na
Gear set screws and loctite?
hi
i've been thinking about using loctite or something on the set screws to the x motor as the load is high and the last thing i want is them to come free during some fine stepping motion.
Is this what most of you are doing?
thanks
dc
Old Mon 04 July 2011, 14:56
timberlinemd
Just call me: Steve #66
Arizona
I would use two screws. First one, shorter length so that there is treads left for second one, set tight to motor shaft. Second one, screw on top of first one to keep from backing out.
Old Mon 04 July 2011, 15:11
giggler
na
hi.
the boss on the gear leaves me with a threaded length for the grub screw of only 6mm. I maybe able to get 3mm long grub screws but would have to look, it's kind of short and think they need atleast 3flutes of the thread so not sure if i can do that.
dc
Old Mon 04 July 2011, 15:22
timberlinemd
Arizona
This would be a problem. Loctite is not recommended. If you search this forum for 'grub screw' you should find solutions for your problem.
Old Mon 04 July 2011, 19:24
I would use longer grub screw, maybe 5mm long. more metal to ensure it bites hard.
Old Mon 04 July 2011, 20:18
Regnar
Just call me: Russell #69
Mobile, Alabama
I think its a matter of what color or type of loctite you are talking about. Red 271 no freaking way. Maybe Green 290 if I was really getting tired of the screws backing off but I do use Blue 242 with no problems. It does require a little more umph to get the screws out so I recommend a new or freshened up allen wrench.
"Grub"/set screws for pinion gears - fitting and locking them. J.R. Hatcher Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 23 Wed 23 June 2010 08:53
Spur Gear decision shelbygt500buddy Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 2 Wed 14 April 2010 05:46
Moore Gear Racks jessyjames The Market Place 2 Mon 15 March 2010 22:32
Pinion gear chatter lunaj76 Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 5 Tue 27 October 2009 01:29
Drilling & tapping the pinion gears for locking screws lunaj76 Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 11 Sat 29 November 2008 05:49
