Old Sun 03 July 2011, 08:54
coinhunter
Just call me: coinhunter
Bogota
Colombia
Parallel port outputs in high!!!
Hello friends, I've been trying to asssemble my first CNC but unfortunately I've had some delays specially because of the computer, some months ago I bought some motors, drivers and the parallel port board from Kelling I assembled and tested them with a computer, they run perfectly, for some reason I got another computer but it doesn't work with the machine, the computer and its parallel port are OK, I've noticed that normally the parallel port pins from 2 to 9 give a low state signal but in my computers the outputs are in high state, I've tried to change some setting from bios that is changing spp standar, esp,or epp modes but it doesn't work, my computer is an old fashioned DELL but enough for my purpose, it has a pentium 4 and it runs windows xp (sp3 version), if you know something about my problem please help me.
Old Sun 03 July 2011, 09:15
Problem is if you port puts out only high state, normally you choose in Mach what is the active pin state, LOW or HIGH.
You can try this software to determine if your LPT port has malfunctioned as it allows you to control the state of pins
http://www.softpedia.com/get/System/...trol-Pro.shtml
If you can change pin states then the problem is in mach or some configuration and computer should be ok.
Old Tue 05 July 2011, 05:27
Make sure the port in the computers CMOS setup is set to BI-Directional.
PMDX parallel port break out card for the MechMate Gerald_D 70. Control Systems 116 Fri 13 December 2013 05:05
parallel port with mach3, or USB with usbcnc? cnc'tje 701. Motor Drives 12 Fri 22 October 2010 09:56
My PC does not have a parallel port - how can I drive the PMDX-122? mrloeng 70. Control Systems 25 Fri 12 February 2010 04:00
Purchasing a good Parallel port cable javeria 60. Wiring & Cable Management 3 Wed 03 December 2008 10:46
Parallel Port breakout - getting the signals from the PC to the drivers Gerald_D 80. Computer Hardware & Software 6 Fri 23 June 2006 08:41
