#1
Motore Stepper directly on the rack
Hello
Can you tell meif it is you can mount a motor directly on the rack without any type of gearbox and stepper motor to take power Thanks |
#2
You can direct drive the system without a gear box. NEMA 34 Motors are what the system uses.
http://www.solarbotics.net/library/p...f/motorbas.pdf Welcome to the team also !!! |
#3
thanks for the reply
But is there any online store where I buy them |
#4
sorry I'm Italian and I could not find anything and indicates some possible
#5
(I removed my previous post since I posted it logged in as Admin)
If you look at the main forum you will see it broken down in sections. http://www.mechmate.com/forums/forumdisplay.php?f=26 Is where I would start. It talks a lot about the different motors. Also look at the "MechMates Already Cutting" and you will see completed builds and can learn from those threads also. |
| UIROBOT Stepper Drives | uirobot | The Market Place | 76 | Tue 31 January 2012 09:45 |
| Rack Metric Size 1.5 | liaoh75 | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 26 | Sun 27 February 2011 03:39 |
| Mounting the rack | blakekoehn | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 16 | Tue 18 May 2010 00:26 |
| Belt or Rack | gustavoosorio | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 2 | Tue 16 February 2010 19:55 |
| Rack alternate | Art | Archives | 5 | Fri 12 September 2008 12:04 |
