Old Mon 13 December 2010, 13:32
agfmaquinas
Just call me: agfmaquinas
Toledo
Brazil
Gecko Problems after Computer Crash
(Moved from motors section)
Hello friends:
I have a CNC router with 4 gecko drives #201.Last week had a ray and burn my computer.I change it and 2 drives for the Y axis dont have signal of direction.The axis work but only in one direction.Any body knows what is going on?
Please sorry about my english.
Marcello from Brasil.
Old Mon 13 December 2010, 17:00
Marcello-
The problem could be with the direction signal between your computer and the gecko drive, or with driving the coils of the motor.
I think it is much more likely that the problem is in the direction signal from your computer. This could be because the parallel port in the computer is not outputting the signal, or because the breakout-board ("BOB", maybe you have a PMDX-xxx?) also got burned, and isn't sending the signal to the gecko. Finally, it could be because the input on the G201 got burned and isn't working any more.
You should measure the voltage at the G201 between pin 8 and pin 1. It should change when you change directions. If it does, the G201 has a problem. If it doesn't, the BOB or the computer has a problem.
Computer desk - glueless javeria The Show Room 13 Wed 12 September 2018 21:05
Keeping dust out of the computer vadeem 80. Computer Hardware & Software 14 Sat 24 August 2013 07:48
Great computer shop cabinet - "Mobile Security Lcd Computer Cabinet Blue" WTI 80. Computer Hardware & Software 5 Thu 29 July 2010 03:33
Computer Modeling Done - New Jersey, USA cvriv.charles Introduce yourself and start planning 38 Wed 12 May 2010 21:01
I'm nearly finished (computer simulation) Euan Stewart Construction started, but not cutting yet 4 Wed 20 June 2007 21:08
