Old Sat 04 December 2010, 06:49
silverdog
Just call me: Sergio #70
Rome
Italy
Imperial vs metric ...
I'm trying some cut with my just finished MM, one of my first cut will be some plywood for my "future" boat ... the "Tini Cat" or Philip Bolger's Catboat.
This is the problem: all the mesures are in this form: 1,2,4 I understend that 1=1 feet, 2=2 inch but the third number ? it coud be 4/16 4/32 4/8 I can't understand,. Can somebody who is familiar with Imperil system explain ? on the book I have there is no reference at all (Build the instant catboat by Harold dynamite Payson"
thanks
Old Sat 04 December 2010, 07:06
silverdog
Rome
Italy
this is what i'm talking about ...
Old Sat 04 December 2010, 07:13
JamesJ
Kansas
Sorry I don't recognize those measurements. Have you tried his forum?
http://www.instantboats.com/phpBB3/
Old Sat 04 December 2010, 07:15
JamesJ
Kansas
Maybe the Yahoo group?
http://groups.yahoo.com/group/Instantboats/
Old Sat 04 December 2010, 09:12
let me guess...
the 2nd figure never greater or equal to 12 & 3rd digit never greater or equal to 8...
so
1.4.2 ->1ft 4 2/8 inches?
1.1.5 -> 1ft 1 5/8 inches?
0.11.1 -> 0ft 11 1/8inches?
0.11.7 -> 0ft 11 7/8inches?
Old Sat 04 December 2010, 11:32
silverdog
Rome
Italy
let me guess...
so
That's what I thougt (all other part of the project are never greater or equal to 8)... but I'm totally ignorant on imperial system .... so I thought I was maybe missing something ....
thanks everybody
in any case I will ask the instant boat forum, thanks James
Old Sat 04 December 2010, 12:49
JamesJ
Kansas
The forum is probably the fastest way to get an answer. My guess would be that maybe the first separator is a comma and the second separator is a period. Something like 1, 1.5 means one foot and 1.5 inches. I have never seen Imperial measurements like these.
Old Sat 04 December 2010, 14:27
Sergio,
The most accurate way to ensure the proper length is actually to the conversion in the native documents. The rounding or "alternate units" out of autocad when the dimensions were created can be set to round up or round down or be the most significant digit chosen. SInce the MM was created natively in the Metric (SI) units system, it's safer to use metric if you doing a lot of calcuations then convert at the end to reduce rounding errors.
During my build, I just used the metric measurements and converted. 25.4mm = 1 inch. I work in "imperial" units and this was the most accurate for my builds. example. So, if your cutting area is 48" x 96", that would be 1219.20mm x 2438.40mm
I have built three machines to date with great success keeping it all metric until that end of each equation.
Old Sat 04 December 2010, 14:49
silverdog
Rome
Italy
Sean, I understand your point, but my problem/doubt is that I can't be sure of what is written on the project. 0,3,3 can be 3 inches 3/8 can be 3.3 inches, 3 inches 3/16 ... I thought it was just a question of my ignorance on using the imperial system but it it seems that this kind of notation it's just not clear. I can't be sure nor in mm nor in inch .... so maybe the x/8 is the right thing but to be sure before cutting .... I think I have to ask in the instant boat forum. Sorry, I thought that it was something clear for an imperial born people.
thanks
Old Sat 04 December 2010, 14:58
can you give me a drawing # that this occurs on? I may be able to clarify for you.
Old Sat 04 December 2010, 15:08
Sean, Sergio is not having problems with the MechMate drawings, he is trying to build a boat with it and the dimensional notation in the book he is working from does not make sense (not that any imperial dimensions make sense! ) Look at post 1 & 2 above.
Old Sat 04 December 2010, 15:22
oh...thanks Alan. That makes a bit more sense.
Old Sat 04 December 2010, 15:28
silverdog
Rome
Italy
Ok, I had an answer !
for example: 0,8,2+ means: 0 feet,8 inches, 2/8 inch and + is 1/16 of inch .....
I'm very happy to live in a mm country !!
Ciao
Old Sat 04 December 2010, 22:39
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
You've found the right answer.
Boat offsets ("dimensions") are given as Feet, Inches, Eighths.
So 3-2-1 means 3'-2 1/8"
This isn't really an artifact of imperial dimensioning as it is a peculiarity of boatbuilding. Boatbuilders are the only ones who use this weird notation.
Old Sun 05 December 2010, 08:21
...Or theatrical lighting! A par 64 is 64 - 8ths in diameter (or 8 inches) I really should have picked up on the notation shorthand. Boatswains and Theater riggers came from the same place. Brad, your usually quick on this.....
Glad you got your resolution.
Old Mon 06 December 2010, 06:28
chrisd7306
Just call me: Chris
Melbourne
Standard dimensions for large boats are given in feet-inches-eights and sometimes a + or - (+ means add 1/16 or - means subtract 1/16).
For canoes and small boats, the dimensions can be feet-inches-sixteenths and the same + or - but this time 1/32. It depends on the designer and how accurate he wants to be. If the third value is larger than 7 ie 8 to 15, the last value will be in sixteenths eg 1 2 8- is 1 foot + 2 ins + 8/16 - 1/32 = 1 foot 2 15/32 ins.
The designer should give the information on which system is being used.
Metric is so much easier!!
Old Mon 06 December 2010, 07:18
silverdog
Rome
Italy
Thanks to all !! Now everybody on the forum knows something more (starting from myself :-) ).
Old Mon 25 July 2011, 10:10
isladelobos
Just call me: Ros
Canary Islands
Spain
imperial vs metric
Vídeo
Rack Metric Size 1.5 liaoh75 Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 26 Sun 27 February 2011 03:39
Fastners Metric or Standard does it matter chris saintdenis General - MM Build 25 Fri 07 January 2011 17:16
Metric versus Inches Gerald D Miscellaneous / General / Whatever / Catchall 23 Wed 07 April 2010 19:16
Metric to Imperial Conversion Site jehayes Golden Resources 2 Thu 09 July 2009 20:22
Metric vs. Imperial plate thickness domino11 Profiled (laser cut) & bent steel plate 8 Thu 04 October 2007 20:49
