Old Sun 31 October 2010, 12:54
Fleischman Chair in Ply
I have wanted to make one of these ever since I first came across his website, not for resale - just out of curiosity
Front View
Back View
Load Test - 100 and plenty Kilos and no creaking or broken slats
Liam with Sheeba and Tequila - Haven't been able to get him out of the chair since I brought it home on Friday!
ps - cant share the files, if you want to make one, work it out for yourself
Old Sun 31 October 2010, 13:05
Pragtig.. I wanted to make them as well...have about 4 different pictures...BUT since I am CAD disabled never got around to do it.....
And he has a REAL beer in his hand...had some of them this weekend in Harrismith at the annual Rhino Motorcycle Rally
Old Sun 31 October 2010, 15:06
Remarkable ! will have to try to draw that
Old Sun 31 October 2010, 15:34
PEU
Just call me: Pablo
Buenos Aires
I recall doing this chair in a vector file, but Gerald deleted it, I can't find that post, maybe it got deleted too
In any case, you did a great job, looks very nice!
Old Mon 01 November 2010, 04:43
taawint
Just call me: taawint
bejaia
Algeria
hello excuse me I speak very little English really good job Excellent
taawint of Algeria
Old Mon 01 November 2010, 05:02
http://chairblog.eu/2008/11/25/lumberest/
Old Mon 01 November 2010, 12:38
Nicly done Alan !
Out of Curiosity here ....How many hrs it took you to :
- Draw it
- Cam ( toolpath) it
- Machine it ( some data on this would be interesting to know & exchange )
Robert
Old Mon 01 November 2010, 13:00
jwt
Just call me: John
Wexford
Ireland
I like this one
Old Mon 01 November 2010, 14:32
Thanks for all the comments
Robert, I will have to check tomorrow on the cutting time, but the drawing took a few hours, in fact it is still ongoing as I want to make one or two changes, The CAM toolpath was very quick, about 5 -10 min on Enroute 3.
John, the caterpillar is nice but I think that one may need to be cut with a laser or possibly with a hand coping saw - look at the centre section where the vertical members meet the foot pieces, no clearance for a router cutter. Some of his other designs are definetly meant for laser, the whole unit has extremely tight slits.
Old Mon 01 November 2010, 20:38
fabrun
Just call me: fabrice
france
France
great job
what thickness do you use?
Old Mon 01 November 2010, 21:11
Cool!!!
I'm looking for a chair design which is friendly for my father's rear end.
How does the chair feels? Springy? does the slats flex to conform to your bottom end?
Old Tue 02 November 2010, 00:36
The chair was cut with 3 passes (8mm slot drill) in 6 stages from 18mm shutterply (not the best material in the world!)
1. Drill centres with a 90 Deg conic - to give me locations to put in screws to hold it down to the table - 1.25 min cutting time (plus about 15 min to put the screws in)
2. Seat external cut out - 8 min - then put a few clamps around the outside of the seat area and screws with flat washers to hold the fingers from moving.
3. Seat internal cut out - 5 min
4. Back outside cut out - 5.5 min - then again a few clamps around the outside perimeter.
5. Back inside centre cut out - 10 min - then insert more screws with flat washers to hold these fingers from moving.
6. Back inside outer cut out - 23 min.
Total cutting time (excluding clamping and screwing) about 53 min.
There were some areas where the cutter did not clean up properly to the bottom of the cut so I passed the cut out through the drum sander a few times to clean up and release everything - at this stage it was a bit like trying to get an octopus through a mail slot - its very flexible. Once assembled its quite ridgid but the slats have plenty of give - at first it feels a little disconcerting but that soon passes. I think it would be a lot better with 22mm ply for a little extra stiffness. This chair MUST be used on a rough or carpeted floor, on my wooden flooring at home the bottom that touches the floor just slides out when I sit on it, but its OK when my son sits on it - maybe I just exceed the safe working limit for this design
Its very comfortable because the seat and back area conform to your body shape easily.
Old Tue 02 November 2010, 03:48
Chair Blog
Just call me: GJE
The Hague (Den Haag)
Funny that my blog shows up here.
Interesting stuff.
Allan. Would you permit me to copy and paste this in my blog?
Old Tue 02 November 2010, 04:13
Welcome GJE, I enjoyed your blog immencely!
Alan, Wow! you are careful with your cuts! Did you use tabs for keep the fingers inplace? I would if I were to cut one with this many fingers...
Old Tue 02 November 2010, 06:42
GJE, I dont have a problem with pasting this into your blog, but I think we need to get Mikes OK before doing so, Oh and you would have to indicate with a link back to this forum where it came from (MechMate).
Ken, no tabs, as long as the appropriate sequence is followed, nothing should move with the screws holding it down.
Old Tue 02 November 2010, 08:22
taawint
bejaia
Algeria
hello thank you for the information and answers you give can you help me for good measure to cut the seat (scaling of X and Y.)
1 - I did the coversion of the drawing in dxf.
2 - I intend to cut with my router table is: (X1300 mm. Y2500 mm)
3-cut on a multiple panel 1220mm sur2440mm
and which is 10mm thick with a bit end mill diameter 6
thank you for your help
Old Tue 02 November 2010, 17:00
Chair Blog
Just call me: GJE
Alan
Not all the stuff, but some photos and a little story. Backlink no problem, but who is Mike? The forum owner?
Old Tue 02 November 2010, 17:22
PEU
Just call me: Pablo
Buenos Aires
The internet was created by people linking to other people, if you show the source and not hotlink the images I see no problem, this is basic netiquette
Nice blog!
Old Tue 02 November 2010, 19:03
Mike, aka Metalhead is the forum owner. You can reach him by pm. Love that chair design!
Old Fri 14 January 2011, 11:34
taawint
bejaia
Algeria
Hello from algeria
Excuse my English I do not speak well
Fleischman Ply Chair in RockNRolla
this is my first chair
My first cut success is thanks to you all on this forum that is more than formidable
a huge thank you mike and alan c
cut with a cutting end mill of 3mm plywood 5mm
Old Fri 14 January 2011, 20:48
I like that.Taawint would you mind me bumming the cutting file my kids would like that
Old Mon 17 January 2011, 11:35
taawint
bejaia
Algeria
Thumbs up
look here is very beautiful
http://www.greggfleishman.com/furniture.html
Sketch a chair, really!!! riesvantwisk Golden Resources 7 Mon 26 July 2010 04:52
