Old Wed 20 October 2010, 07:11
Mojo
Just call me: SolarImages
Bisbee, AZ
Electric kit i have found opinions please
http://www.motiontek.ca/CNCcontrol.html
This is a company in canada. I have looked at the specs on there kit but being still very new I am a bit lost with all the information given and trying to compare between 203v geico's and oriental motors PK296A1A-SG7.2 (i know the kit is missing one motor but the company will add drivers and motors as needed)
Any thoughts would be very welcome thanks.
Old Wed 20 October 2010, 07:59
Use the PK296A2A-SG7.2 motor, not the PK296A1A-SG7.2 motor. The A2A motor has 1.5mH inductance, so it will run very well with a 35VDC power supply. The A1A motor will be underpowered, even with an 80VDC power supply, which is the maximum voltage that the Gecko G203v stepper drivers can handle.
The 23-size motors listed in the kits are too small. You would have to use a belt-drive transmission with a 6:1 or 7.2:1 ratio to get usable torque. A belt-drive with that ratio would have to have a center to center distance of more than 8-inches to have proper teeth contact in the 10-tooth or 12-tooth gear.
The kits show a switching power supply without external capacitors. Stepper motors need lots of current, not constant voltage. You would need to add at least 10,000 uF of external capacitance, 20,000 uF would be better.
The fan is mounted in the side of the case. If you cut MDF, you would have a case full of dust. The recommended procedure is to mount the fan inside the case to circulate the air inside the case. The case itself acts as a giant heat sink.
Old Wed 20 October 2010, 14:06
Mojo
Bisbee, AZ
Thanks a for the input
Thanks for the in-depth insight i had not noticed the A1A model number difference (that is big almost purchased the wrong motor) Did not read that the fan wanted to be sealed inside earlier but makes perfect sense as well for mdf. thank you for taking the time for this insightful input.
Electric Kits MetalHead The Market Place 65 Thu 09 October 2014 19:53
Electric Engraver as a toolhead lumberjack_jeff 50. Toolheads 14 Mon 30 August 2010 20:42
Found this Spindle...please comment Claudiu 50. Toolheads 18 Mon 10 August 2009 08:05
Help for a null electric guy Gato Richy 702. Power Supplies 12 Thu 26 March 2009 01:38
Initial opinions with this geared motor: sprayhead Motors & their mountings 1 Fri 30 January 2009 08:05
