#1
Mach3 to HY series VFD on/off control
Hello all,
I had to replace the spindle on my CNC router after the winding went bad. I took a chance and purchased an Air Cooled 4kw Chinese spindle and VFD, the spindle works good when I used the VFD to stop/start it. I used the same connections on the new VFD- DCM & FOR as were used on my old one. I went into the programming menu and changed pd001 to 1 and pd002 to1. I also made the changes to the ports/ pins output setting in mach3. I still have no stop/ start via mach. Any help would be greatly appreciated. thanks Jon Alwine |
#2
Jon,
Are you certain that the DCM and FOR are the correct location? Additionally, check to make sure there is not a secondary setting after enabling the contact closure for "std run or " 3 - wire run" functionality. On occasion, you have to also tell it to DISABLE looking for a rs232, +/- 10VDC or 4-20ma potentiometer control. Can you post a link to the manual, I might be able to assist further. Sean |
#3
The next to the last post on this thread has a wiring diagram along with good info on setting it up. It helped me quite a bit, but I am not running Mach, so I can't help on that section.
http://www.mechmate.com/forums/showt...hlight=chinese Ken |
| Solid State Relay (SSR) for switching Router under control of Mach3 | Gerald_D | 70. Control Systems | 77 | Tue 07 January 2020 18:43 |
| Finished writing plugin for Mach3 to control the VFD via RS-485 - Adelaide, Australia | MattyZee | MechMates already cutting | 99 | Sun 06 March 2011 04:05 |
| In need of a little advise from the experts...series or half-coil wiring? | jeffa | Motors & their mountings | 7 | Mon 17 August 2009 11:57 |
| Delta Variable Frequency Drive VFDB series - (for the spindle motor) | Gerald_D | 701. Motor Drives | 8 | Tue 25 November 2008 10:08 |
| Power supply transformer - series/parallel of the output (secondary) side | ekdenton | 702. Power Supplies | 2 | Wed 27 February 2008 08:01 |
