Old Thu 09 September 2010, 16:51
Mojo
Just call me: SolarImages
Bisbee, AZ
Angle Iron rails
How long should i expect the angle iron rails and bearings to run out true if i am putting about 20 hours a week on them cutting wood?
Old Thu 09 September 2010, 22:50
Zero.
Old Thu 09 September 2010, 22:59
Mojo
Bisbee, AZ
Zero...
Old Fri 10 September 2010, 04:47
I used my machine for 2 years far more than that.....sometimes 60 hours straight before changing out the 3d part. Zero noted so far.
Old Fri 10 September 2010, 09:28
Mojo
Bisbee, AZ
Thanks for your time in this. Sean
Old Fri 10 September 2010, 10:14
Note: I take the time to continually clean the machine and lubricate the rack and rails with SLICK TOP table saw table lubricant to keep it all nice and dust free and moving.
Old Fri 10 September 2010, 10:26
Mojo
Bisbee, AZ
I will keep that in mind with my machine. Currently i have decided to go with with hardened rails from Rick at superior, but i am sure cleanlyness is key in this machines longevity. thanks again for the input Sean.
Old Thu 01 December 2011, 17:13
Slipery
Just call me: mal
Toowomba
Zero.
I must be misunderstanding this question or the answer. Are you saying the X bed will never run true?
Old Thu 01 December 2011, 17:53
The question was what kind of wear should be expected using the machine 20 hrs per week. The response was zero....or close to that.
I have not noticed any wear that has affected cut quality after many years with the standard ground rail system.
Old Thu 01 December 2011, 19:53
Slipery
Just call me: mal
Toowomba
Ok thats make sense thought we were talking about Totail indicated runout or such
DIY-rails Which type of angle iron must be purchased? oddname Rails & Rollers 6 Sat 14 November 2009 07:41
Cutting the angle iron down with grinder and abrasive disk Alan_c Rails & Rollers 39 Mon 13 July 2009 11:15
Why does the angle iron have to be cut shorter for the rails? chopper Rails & Rollers 8 Thu 10 July 2008 21:28
M110110M Angle iron rails for X and Y axes Gerald_D Rails & Rollers 69 Sat 15 September 2007 17:17
Thoughts on the angle iron rails of the MechMate Sheldon Dingwall Archives 15 Wed 07 March 2007 14:07
