Old Thu 15 July 2010, 11:07
renraku
Just call me: renraku
rome
Italy
inverter wiring help
Hi i needs of a suggestion:
1) electric power connects to the inverter
2) inverter is connects to the spindle
answer: where is connects the inverter for change the speed of the engine?
Can Mach3 change the speed of the spindle through the inverter
what is the correct connection to PMDX 122 and inverter?
Old Thu 15 July 2010, 11:16
The PMDX122 can not control the speed of the spindle.
Old Thu 15 July 2010, 11:51
The PMDX 122 does not offer this, but the PMDX-106 WITH A PMDX-125, PMDX-131, or PMDX-132 using 10 pin ribbon cable (available separately) will give you speed control over spindle with the appropriate I/O. This is a 2 card combination.
Old Thu 15 July 2010, 12:26
Actually, I think you can use the PMDX-106 with a PMDX-122 (and discrete wiring), or with the 10 pin ribbon cable to the 125,131,132. The PMDX-107 requires the 10 pin cable, and thus only works with the 125,131,132. At least if I'm reading the docs correctly.
It's worth noting that just an optoisolator, a couple of resistors, and a capacitor can be used to take any single pin output from a BOB and make it into a speed control for an inverter. That's if you are comfortable cobbling up a quick handwired circuit board.
Old Thu 15 July 2010, 13:02
renraku
rome
Italy
Thanks so much
Old Thu 15 July 2010, 14:39
Brad,
and quietly noting that is exactly what I did on the 4th channel on the test bench with another multi-axis project. It didn't take long - but was worth it.
Note:
Brad, you would have liked it...it was for an x/y translating wagon for a show with a rotating car on top that I needed VFD speed control over. Some quick hackery for a one-off show. Theater stuff 101!
Wiring quality Gerald_D 60. Wiring & Cable Management 61 Wed 26 October 2011 18:24
VFD wiring - right or wrong javeria 60. Wiring & Cable Management 12 Tue 27 July 2010 20:41
Lowest price Spindle/Inverter yet - $423 WTI 50. Toolheads 9 Thu 30 July 2009 19:51
The worst way of wiring . . . . . Gerald D 60. Wiring & Cable Management 8 Sun 23 November 2008 19:58
Wiring the motors GregA Archives 1 Fri 11 January 2008 08:39
