Old Mon 14 June 2010, 05:56
helow
Just call me: asad
fsd
Anguilla
running stepper motor with printer data pcb board
hi
i have got a stepper motor(i think it is 12V) from a laser printer. I am thinking to run it through large floppy drive (about 5"), but i think it could not run it with full power. thats why i want to use printer's data pcb board to run it. but i need some guide about pins of data and power connector. plz may you help me.
Thanks in advance
Asad
Old Mon 14 June 2010, 06:30
Asad, this forum concentrates primarily on constructing MechMate CNC routers, and MechMates are not generally built from those types of parts.
I suggest that you ask the question elsewhere. Unfortunately, the type of information you are requesting is generally proprietary to the manufacturers, and may not be readily available. If there are any part numbers on the motor, you might try googling on them. The printer's pcb board is probably not reusable.
Running 5 drives off one PMDX-122 board J.R. Hatcher 70. Control Systems 40 Tue 19 December 2017 10:21
True Torque of a Servo motor for comparison to a Stepper motor, when used in a router Mcyoda Motors & their mountings 3 Tue 19 August 2008 00:50
K4- Bipolar Stepper Controller Board javeria The Market Place 0 Tue 29 January 2008 18:26
What mode are u running your motor - Unipolar Bipolar eloid Archives 3 Thu 22 March 2007 21:23
