Old Wed 26 May 2010, 04:42
tomasptacek
Just call me: Tom
Prague
Czech Republic
Steel L profile
Hi Gerald,
the nearest steel L profile to support rails I can get is 60x40x5 mm (attachment). Can I use it or do I have to cut it to 60x21x5 mm ?
Tomas
Old Wed 26 May 2010, 05:36
Polder48
Just call me: polder
Edam
Tom
Look at drawing M1 10 110, there you'll see that the final height of the rails will be 28 mm. So first you have to grind the rail down to 28 mm, then you must grind the 45 degree angles.
Search this forum for the various ways how this can be done
As starter your angle iron will be fine. Good luck with youre build.
Polder
Old Wed 26 May 2010, 06:00
tomasptacek
Just call me: Tom
Prague
Czech Republic
Hi Polder, I did not explain it well. L profile would be just support for the rails. See atachment.
Tomas
Old Wed 26 May 2010, 08:37
Polder48
Edam
Tom,
Then have a look at drawing M 10 120. Specialy the remark that you have to make a fillet radius etc.
You can still use youre angle iron. 40 becomes 16 mm measured from the inside. That will do fine
Polder
Profile cutting with cnc mill? esadaddy Profiled (laser cut) & bent steel plate 6 Sat 27 September 2014 19:23
Pre-finished steel rails from Standard Steel Specialty dmoore Rails & Rollers 0 Thu 01 May 2008 16:28
How many laser profile cut components required per part number? fabrica Profiled (laser cut) & bent steel plate 29 Mon 07 January 2008 12:32
Grinding V-profile on rail edges Gerald_D Archives 65 Fri 24 November 2006 10:07
