#1
Hello MM builders...
As many of you are aware, the search facility on the mechmate.com website lacks the search flexibility and depth we are now accustomed to with google, yahoo and others due to the software limitation. I have created a BETA "Custom Google Search" specifically locked down to the www.mechmate.com URL which means that only results from the MechMate website will show. Use whatever wild cards you are used to using in Google to find things and you should be surprised that it works well. ![]() The URL is located here: www.rcbits.com If everyone is happy then MetalHead needs to commission a website developer or spend time himself to embed this code into the forum header page under his / her own google account. NOTE: PLEASE DO NOT CLICK ON ANY ADVERTISEMENTS NO MATTER HOW TEMPTING ON ANY PAGE THAT APPEARS AS THIS WEBSITE IS CONNECTED TO MY GOOGLE ACCOUNT WHICH MEANS MECHMATE WILL NOT GET ANY REVENUE FROM THE ADD CLICKS!!! ![]() ![]() ![]() |
#2
If you look at CNCzone, as an example, you can see Google search embedded as an option under the Search button. It is fairly common in vBulletin and there are a couple of free plugins available to implement it. You can see here that I investigated it some time ago. I can't remember the exact reason why I didn't implement it, but one of the reasons was that Google only visits and indexes every week or so, and thus the last week's info won't show up on Google search.
Anyone can make Google search only in a specific site by adding site:mechmate.com with the search words. |
#3
An even better option Gerald
, i will disable the searching of that site for www.mechmate.com and will now use the site:mechmate.com xxx where xxx is the word you want to search for in the google search bar. |
#4
Google now has realtime search if you supply google with a proper feed of the site.
On some sites I implemented a sitemap file and there info appears in google within 15 minutes, it's up to google however to decide how often it will index it. However, mechmate.com seems really active so I dont' expect any long delays. Ries |
#5
The syntax for seaching is XXXXX site:mechmate.com
Example "belt drive site:mechmate.com" you can go advanced and limit the age of the search also. |
| Search functionality | lumberjack_jeff | Archives | 5 | Mon 15 June 2009 19:58 |
| Web hosting search & info ! | Robert M | Miscellaneous / General / Whatever / Catchall | 6 | Wed 27 May 2009 03:58 |
| Cutting in the UK! Electrical noise problem solved! - Darwen, UK | Barrie | MechMates already cutting | 5 | Fri 01 May 2009 09:25 |
