Old Sun 21 March 2010, 09:48
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
Straight-flute bits and safety
I was cutting parts out of 1/2" cdx ply last week when I found that at each corner of somewhat complicated shapes (i.e. slow feed ipm) the friction caused small burning spots. (And no, the bit was not dull)
Ordinarily not a huge problem, except I was cutting the material in two passes, and when the dust collector passed over the smouldering spot (filled with unejected chips and dust) on the second pass...
No harm done, but it was pretty scary seeing those sparks go up the dc hose.
From now on, it's upcut for me.
Old Sun 21 March 2010, 10:30
Jeff,
Would you share a little bit more information about the cut? Like what speed was the router and what feed rate you were going?
Old Sun 21 March 2010, 13:38
lumberjack_jeff
Montesano, WA
20,000 rpm, 180ipm on the straightaways.
The points at which burning occurred were probably 10ipm - sections composed of short line segments and reverses of direction.
Old Sun 21 March 2010, 14:51
rayditutto
Just call me: Robin
Victoria
Send a message via MSN to rayditutto
.25" or .5"?
1 or 2 flutes?
do you have a pic of the bit?
cheers,
robin
Old Sun 21 March 2010, 18:05
lumberjack_jeff
Montesano, WA
Basic two-flute .250 bit.
Freud, I think.
Old Sun 21 March 2010, 23:48
rayditutto
Just call me: Robin
Victoria
I'm perplexed and concerned - perplexed because i don't see a clear answer and concerned because, well, it's fire
this is pure speculation but, here goes . . .
on straight flute cutters as you've described, the cutting edges on the bottom appears (i've not actually measured it) to slope upwards to the centre ever so slightly - also, the blade does not go all the way to the centre which is problematic when plunging
perhaps it is possible when the bit is moving slow that the bevelled bottom edges pack sawdust at the centre of the bit where friction creates the smoke
sawdust might pack into the center of the bit even if the bottom edges were not bevelled
still baffled,
robin
Old Mon 22 March 2010, 09:18
lumberjack_jeff
Montesano, WA
CDX ply is the only material I've noted this in... but then again, I use straight bits rarely now.
I think you're right, every place it happened was a place where the tool came to a near-complete stop as it negotiated a turn.
Old Sat 27 March 2010, 11:07
ger21
Just call me: Ger
Detroit, MI
I'm curious as to why it's slowing from 180ipm down to 10 ipm?
Also, 20,000 rpm is probably quite a bit higher than you need at 180 ipm. Try lowering the rpm's down to about 15,000.
But, the bottom line is you shouldn't be cutting wood at 10 ipm. You need to figure out how to avoid that. Can I see the code, or get more info on what's causing the slow speeds?
Do you have a very low accel setting?
Old Sat 27 March 2010, 13:20
lumberjack_jeff
Montesano, WA
Thanks Ger,
I am now testing SheetCam. The postprocessor is much better optimized for EMC.
It is exactly true that I have a problem here with the code. But the problem was made serious (as opposed to simply inconvenient) by straight bits.
My accel settings are pretty low, an artifact of trying to solve a missed steps problem.
Getting rails coplaner and straight waynec 10. Base Table 20 Thu 30 December 2010 02:08
Cutting bits for routers / spindles fabrica Cutting various materials - bit selection, feeds, speeds 70 Sun 27 June 2010 09:20
Setting the rails straight Gerald_D Rails & Rollers 12 Thu 24 June 2010 13:20
Up Spiral Bits PEU Cutting various materials - bit selection, feeds, speeds 24 Sat 27 March 2010 11:04
Design safety - what has not yet been tested for safety, etc. Gerald D General - MM Build 0 Mon 09 February 2009 04:41
