Old Sun 07 March 2010, 09:15
cnc'tje
Just call me: newbie
Brussels
Belgium
The setup of 2 motors on 1 axis
Hey you guys,
im looking to build my own custom mechmate, with a large cutting envelope of 3100 mm x 2100 mm x 150 mm.
I have a lot of expertise with the cad/cam part, but i'm just a newbie if it comes to building an entire cnc machine.
It seems to me that all the large mechmate's have got 2 motors on the X-axis. Do i need a 4-axis break-out board for this, or not?
I was wondering because both the motors work on the same speed all the time, but they do work against each other. ( to go in one direction, one runs CW, the other CCW)?
Can i solve this "problem" by using a normal 3-axis break out board, and just use the the same pulse and direction signal for the two motor drives? hoping that i can make one stepper motor turn the other way, by switching the cables that come out of the motor???
Im sure some of you guys can help me out with this one. . .
I really hope my spelling is correct, and that u can understand my english
looking forward to youre response.
Old Sun 07 March 2010, 09:55
Hi your logic is perfectly correct, you can use a 3-axis breakout board.
However, there is a facility in Mach3 for "auto-squaring" the gantry, where independent control of the gantry motors is used. But, most people do not use the auto-square.
Old Sun 07 March 2010, 10:38
cnc'tje
Brussels
Belgium
thx Gerald, for the fast reply.
Now i finally can order my breakout board.
I guess my english wasn't so bad after all. . . .
Another workholding setup lumberjack_jeff General - MM Operating 15 Tue 29 September 2020 02:31
Setting the Y-axis square to the X-axis Gerald_D 20. Gantry 10 Fri 12 October 2012 00:44
How many motors use mechmate in the long axis albertoslayer Motors & their mountings 11 Tue 09 March 2010 10:44
Setting A-axis terminal as X2-axis in EMC2 KenC CNC motion control software 2 Wed 27 January 2010 05:40
Rotary axis (4th Axis) or Indexer software smreish Graphics & CAD 0 Tue 28 July 2009 06:02
