Old Sat 16 January 2010, 17:27
m_leblanc
Just call me: MARS
SHAWINIGAN
Relay info
Hi to all
I have come across this relay and I would like to know if I can use it for powering or shutting down my router (15 amps, 120 VAC).
My BOB is a PMDX-122 and the relay is identify like this:
Type:30E0302DCSV
ESI NO: 4052Y5B-32
COIL: 24 VDC
UNISYS
4914999-06
VOLTS:240V :480V :600V
FLA/POLE:30A :30A :30A
RES/POLE: 40A :40A :40A
LRA/POLE: 180A :120A :120A
LRA 3PH 3 POLE:150A :120A
FASCO IND INC
ELDON MO. USA
So far with the little electrical knowledge that I have, I have been lucky to not blow any smoke, so I rather ask before doing anything else.
Thank you
Old Sat 16 January 2010, 23:13
Mars, that looks like it is a "contactor" that needs a 24V DC control signal. Will you have a 24V DC control circuit?
Old Sun 17 January 2010, 01:51
m_leblanc
Just call me: MARS
SHAWINIGAN
So what will I need to be looking for to get my router turn off and on regarding a relay or contactor, without adding more control circuit.
Thank you for the reply
Old Sun 17 January 2010, 01:56
If your router is 115VAC, use a contactor/relay with a 115VAC coil (Canada is 115V I think?)
Old Sun 17 January 2010, 20:09
Canada is 115V for routers. Looks like that contactor would work if you had the 24V drive.
Old Mon 18 January 2010, 03:25
You can use an external D.O.L. (direct on line) starter, its a box with an ON & OFF button & a contactor inside.
Hope this helps
Old Sat 23 January 2010, 12:12
m_leblanc
Just call me: MARS
SHAWINIGAN
Hi, thank you all for the help you are giving me, I found this SSR on Ebay and I would like to know if it would work with my BOB.
I have been trying to insert the link but I can't manage to do it, so here are the specs.
Size 57.4mm X 44.8mm X 28mm
Load Current 60A
Load Voltage 480V AC
Control Voltage 3-32V DC
Control Current DC 3-25mA
On Voltage ≤ 1.5V
Off Leakage Current ≤ 2mA
On-off time ≤ 10 mS
Dielectric Strength 2500V AC
Insulation resistance 1000MΩ/500V DC
Ambient Temp -30~+75℃
Mounting methods Bolts
Working indicators LED
Old Sat 23 January 2010, 14:48
Mars, the control input side of that SSR seems compatible, and is what you should be looking for. However, the load size is way, way over what you need for a router - something more like Current 20A , and Voltage 120V AC would be more reasonable.
I suspect that that SSR would work, but it's overkill. You might try something like this: http://www.factorymation.com/s.nl/it.A/id.753/.f
Old Sat 23 January 2010, 20:44
Also see Solid State Relay (SSR) for switching Router under control of Mach3 , particularly posts #29 and #30.
Driving a relay using 2n3904 javeria 70. Control Systems 8 Tue 29 September 2009 21:18
Info - all in French yamsx600 General - MM Build 2 Sat 04 July 2009 11:07
PMDX-122 relay output voltage? chopper 70. Control Systems 10 Thu 04 December 2008 07:00
Programmable Relay to Watch Dog the Limit/Home sequence smreish 70. Control Systems 13 Mon 07 January 2008 05:28
Selflatching relay/contactor Mike Richards 70. Control Systems 0 Sun 25 February 2007 15:20
