Old Sun 08 November 2009, 03:35
PoKeys55
Just call me: Boris
Ljubljana
Slovenia
Lightbulb PoKeys55 - 55 USB IOs, analog digital, MPG...
PoKeys55 is an easy-to-use USB device that combines standard keyboard and joystick simulation, and do not requires complex programming knowledge. Pokeys55 provides 55 digital I/O (5V tolerant), 5 analog inputs (10-bit) and 1 analog output (10-bit). All the I/O are controlled by the provided software which allows either to use the graphical user interface or advanced console type interface. The settings can be stored on the device, so no special software is needed on target system. PoKeys55 can be used as industrial or CNC control, custom joystick or keyboard or data acquisition board. PoKeys is available with (PoKeys55-T) or without screw terminals.
Features:
* Compatible with USB 1.1/2.0 HID standard.
* Standard USB keyboard simulation.
* Standard USB joystick simulation.
* 55 digital inputs (can be used as virtual keyboard keys).
* 55 digital inputs and outputs.
* 5 analog inputs 10-bit (can be used as virtual joystick axes).
* up to 25 incremental encoders can be connected
* up to 8x8 matrix keyboard can be connected
* up to 6 PWM outpus
* up to 4x20 characters LCD can be connected
* Software controlled 10-bit analog output.
* Up to 255 units can be connected to one computer.
* Intuitive and user-friendly software.
* Plug-in for Artsofts Mach 3 CNC software available.
More info, demo software, manuals on: www.poscope.com
digital stepping driver KenC 701. Motor Drives 7 Sun 20 June 2010 10:20
A different digital clock . . . . . PEU General - MM Operating 21 Sun 27 September 2009 18:38
Digital file from reverse engineering - can MM be used to scan a drawing? skypoke Utility software 12 Mon 01 June 2009 05:17
Smoothstepper USB to parallel converter Gerald D 70. Control Systems 25 Tue 19 May 2009 03:28
USB Ports on the Y-Car - no really... dmoore 60. Wiring & Cable Management 7 Sat 24 May 2008 15:54
