Old Thu 09 November 2006, 12:16
Copied from another thread:
That "tapered hob" issue: A hob is a tool for cutting a gear, why is Oriental practically the only company in the world that makes an issue of the tool with which the gear is cut? Its like saying my house was built with a 2lb claw hammer - why is that supposed to make a difference?
Old Thu 09 November 2006, 13:12
Dirk Hazeleger
I have no idea as far as the tapered hob issue. They don't publish the spur gear spec, and I think the rep was guessing when I asked him. It would be interesting to break down both reducers and see what the real difference is.
Old Thu 23 November 2006, 21:48
The "tapered hob gear" is actually a "taper gear". From a newsletter:
I suppose the pitch diameter is an average across the width of the gear.
Old Tue 20 October 2009, 10:45
The above posts bumped for Mike
From the picture, the tapered gear is only on the final meshing pairs of teeth - there are one or two pairs before that without wear compensation (no. of pairs depend on overall ratio).
Unless the tapered adjustment is spring-loaded, the gears will not self-compensate for wear. There is probably a wave washer behind the tapered layshaft.
The wear rate could be higher because the tapered gear has a sliding action between parts of the gear teeth (the small side of the gear has a different "ratio" to the big side) My guess is that the actual amount of taper is very little, otherwise the wear would be high.
Range of gearboxes: http://www.orientalmotor.com/product...ep-motors.html
The output shaft may be the one that is spring loaded. You might be able to feel this if you pull on a TH's shaft vs a SG shaft.
Understanding & Selecting gear pinions - setting the steps per mm[inch] fabrica Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 96 Thu 03 May 2018 05:43
Gearbox Backlash Is this to be expected? Cutter99 Motors & their mountings 4 Mon 15 June 2009 11:07
Where can I find a Motor Shaft Coupler for planetary gearbox? rocky2889 Motors & their mountings 2 Tue 03 March 2009 20:11
Problems with square washers (also called taper or bevel washers) gmessler 10. Base Table 7 Sun 16 November 2008 05:12
Checking Parts List confirmation of pinion & gearbox DocTanner Motors & their mountings 21 Fri 09 February 2007 11:53
