Old Mon 12 October 2009, 19:41
kanankeban
Just call me: Hector #89
mgWesGD
Western Sahara
How many CAR STOPPER BLOCKS do I need?
Maybe is a dumb question...sorry if so, I can clearly see that 2 are needed for the x axis, but I cant find how is done on the y axis, Its just one on it?, and if so does it matter in what y rail is installed?
Old Mon 12 October 2009, 21:03
One stopper block near to each X and Y motor.
Old Wed 14 October 2009, 22:03
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Hector: I'm glad you asked this question, I was too embarrassed to ask it but still am not sure where to mount them. I have welded the stopper blocks (10 10 248D) to each end of each x and y rails (per drawing 10 10 200A) but am not sure how to mount the car stopper and limit switch assembly (M1 18 000A/B). I assume it is placed on the inside of part 10 20 400W on the gantry assembly (per drawing 10 20 000) but I am unsure where each should be placed. If it is centered won't the wheel on the far end run off the rail before the limit switch hits the stop? Same question for mounting on the gantry car.
Also. Does the 3/4" sensor hole in the rail for the limit switch need to be extended all the way through the main X-beam, or is the hole in the rail sufficient? Thanks
Joe
Old Wed 14 October 2009, 23:35
Originally Posted by jehayes View Post
. . . If it is centered won't the wheel on the far end run off the rail before the limit switch hits the stop?
It is centered in the moving car/gantry. (The screw holes are already laser cut in those moving parts). The stops and holes in the static rails are located well before the ends of the rails.
The hole in only the rail is sufficient - the proximity switch is positioned so that it is blind to metal more than a 1/4" away.
Old Thu 15 October 2009, 10:41
jehayes
As always, thanks Gerald
Attachments to the Y-Car Gerald D 30. Y-Car 7 Tue 17 February 2009 08:33
Wooden bike, wooden sports car, botox car and carrying bricks . . . normand blais Miscellaneous / General / Whatever / Catchall 30 Wed 11 February 2009 13:11
Stop blocks for alu rails smreish Rails & Rollers 1 Sun 28 September 2008 16:59
M1 18 000 Alternative Stopper Block dmoore 20. Gantry 15 Fri 13 June 2008 12:47
Round shafts & ball slide blocks versus V-rails & V-wheels joepardy Rails & Rollers 28 Fri 07 December 2007 12:41
