Old Wed 11 February 2009, 02:27
Rollers grooved to 70 degrees by mistake - can they be re-cut to 90 degrees?
HI Folks - the rollers which me and vishnu ordered - turned out to have an angle of 70 degrees.
Now vishnu thinks that plunging a 90 degree v tool would solve the problem
what I think is that the 70 degrees has created more depth(of the groove in the wheel ) and now having the 90 degree tool plunge in will just get it to the same changed depth - I have a hunch that it would work - just wanted to get your views
RGDS
IRfan
Old Wed 11 February 2009, 05:07
The profile should have followed the yellow line. You now have 70 degrees to the magenta line. If you put in a 90 degree cutter now, it will go to the the blue line. That means your rollers will be 2mm smaller in effective radius. Not too serious.
Old Wed 11 February 2009, 06:28
thank you G'
hey vishnu - I am sending all my rollers back to you for re-machining - or will you send me the tool direct - I can get em machined here faster
Old Wed 11 February 2009, 10:21
vishnu
Just call me: vishnu
Coimbatore(TN)
Hi,
Today i have plunged the rollers with 90 deg form tool and mounted the wheels atlast it worked. The movement was smooth and satisfactory. I will send you the tool & mandrel , it takes about 2 monutes for one wheel , lets keep things moving.
Vishnu
Old Wed 11 February 2009, 11:40
There tag team wrestling now we have tag team building..... keep the build going.
