Closed Thread
Old Sun 16 November 2008, 17:06
eesanopi
Just call me: Edgar
Morelos
Mexico
Butcher saw V-wheels on e-Bay - can they be used?
Hi,
I'm in the proccess to acquire the components for my CNC router, I found this wheels in ebay:
http://cgi.ebay.com/V-Groove-Butcher...742.m153.l1262
This kind of V wheels are used in butcher saw machines, they are real steel ball bearings and price is low, I think they are sealed, because they must be designed to work in the wet and dirty enviroment of a butcher shop.
What do you think about it?, Could I use this bearings in my project?
Any help will be grateful
  #2
Old Sun 16 November 2008, 18:08
Those bearings on first glance look to be a little small in diameter compared to the ones that are specified for the mechmate. Hard to tell without dimensioning. Also the V groove looks to be larger than those specified for the mechmate. The v bearings are probably one area that you would not want to deviate too much if you would like the performance of the design to be maintained.
  #3
Old Sun 16 November 2008, 18:40
Ebay page says these are "V" groove . 1 5/8" diameter, 3/8" core , 1/2" wide. Ball bearing center core.
BWC size 3 are 1.8" or so, just under 1/2" bore IIRC.
I agree with Heath, you may have trouble in a number of different spots: you'll have a lot less eccentric (if any) to work with on the Z axis due to the 3/8" bore. The diameter change will affect some of the clearances on the X and Y axis, although I can envisage a little grinding if it's too close.
Finally, as Heath points out, if that V is too wide (or not at 45 degrees), you'll have to re-engineer the rails, and that sound pretty scary.
  #4
Old Sun 16 November 2008, 19:37
This is one area I would not want to deviate from. The performance specifications on the real #3BWC or Superior Bearing equivalent meet some very critical criteria - namely horizontal thrust, and vertical gantry/y-car ride height.
The bearing diameter dictates the gap distance between the motor mount swing arm and the pinion. This vertical dimension does not like to be changed.
I would stay with the specified bearings in the package or purchase the appropriate ones.
  #5
Old Mon 17 November 2008, 00:21
This thread originated on the CNCzone:
http://www.cnczone.com/forums/showthread.php?p=527253
  #6
Old Mon 17 November 2008, 20:12
eesanopi
Just call me: Edgar
Morelos
Mexico
Hi,
I'm in love with the mechmate machine design, but in this moment myCNC project is limited in budget, however I was thinkin a lot in your opinions because in the future I'lll construct a mechmate, I'll go for original V bearings.
Thanks for your comments.
Closed Thread
