Old Fri 20 August 2010, 03:42
AuS MaDDoG
Just call me: Tony #71
Brisbane
Niceeeee I like it !!
Tony.
Old Fri 20 August 2010, 04:51
salewis
Just call me: Stan #67
Littleton, NC
Yeah, I "borrowed" the idea from someone else. Tried it out yesterday. It sucked
But I've got to make another one because the dimension between the router and the DC pipe is too small.
I'm getting all this experience making parts for myself that I wonder if I will ever make parts for someone else
Stan
Old Fri 20 August 2010, 08:22
Which machine are you using to cut the parts.....your old cnc or your new MM?
Old Fri 20 August 2010, 22:51
crashingsucks
Just call me: doc #67
NC
We are cutting with the yet to be painted MM!!! Our first job is almost at hand, so we are going to finish that job and then add blue paint.
Think of our paint-less MM as a car that is getting restored that's being driven in primer only..... Here in the US it happens a lot
Old Sat 21 August 2010, 06:26
salewis
Littleton, NC
Actually most cars being restored are required to have multiple colors of primer
Old Tue 24 August 2010, 13:14
polishpickle
Just call me: Jerry
Medina
Where did you get the vinyl skirt?
Old Tue 24 August 2010, 20:09
barry99705
Just call me: Barry
Xenia
I've asked a chick in a bar that once.
Old Tue 24 August 2010, 23:44
crashingsucks
NC
Ok, I lost my last post, let me try again.
My build partner made the vinyl skirt from some sheet vinyl.
I love the post above, it made me think of the time I saw some blue jeans with vinyl back pockets....yes they were in use......and they were on a girl.....
As far as the present vinyl skirt, it needs to be adjusted, it was too long and got in the way thus it was ripped off in the process....
It's all in the interpretation
Old Wed 25 August 2010, 06:56
If the vinyl strips are not stiff enough, they get sucked into the cutter!
I had to convert my 1st shoe to bristle brushes like MM #1 to keep that from happening.
Old Wed 25 August 2010, 07:37
polishpickle
Just call me: Jerry
Medina
I had that style vinyl on my first shoe but it wasn't that long. Also it had 2 layers and the cuts were staggered so one piece wuld seal the next
Old Wed 25 August 2010, 17:36
salewis
Littleton, NC
The vinyl came from McMaster (or is that MechMaster )
From building this shoe and the one before that (and the one before that on my old machine), it is compromise....
Large dust foot to vinyl strip length, more of a measure of distance from cutter centerline. Also amount of suction is a consideration (harder to suck the vinyl in when it is pointing outwards).
Then there is the 3d issues....
and I thought the building was over...
After visiting JR, I think that there is no such thing as a completed MM
Old Thu 26 August 2010, 03:02
Originally Posted by salewis View Post
.... I think that there is no such thing as a completed MM
mine will ever be complete too
Old Fri 27 August 2010, 05:28
salewis
Littleton, NC
never complete.....
I'm doing the research for zero plate and laser crosshairs... Too cool on JR's machine, kudos to Greg et. al. for all the work....
Will post some q's in the appropriate section..
Old Mon 18 October 2010, 14:25
salewis
Littleton, NC
Z Zero Plate and Laser XHairs....
Got them both working ... sort of...
Laser is great and dirt simple...
Zero Plate is giving me a bit of heartburn.. Everything works right in pieces (ie. macro, plate, BoB). Put together it gets more than a bit flaky.
Like right after touching at a nice smooth (and slow) pace, mach3 tries to g0 the bit down about a 0.5 inch OUCH.....
Time to troubleshoot some more. any thoughts on "debounce" settings to give Mach a bit of room to work with?
Old Mon 18 October 2010, 15:21
rayditutto
Just call me: Robin
Victoria
Send a message via MSN to rayditutto
try 2" copper wire 10 or 12 gauge clipped to the bit - it will bend much better than your bit
cheers
Old Fri 22 October 2010, 17:52
salewis
Littleton, NC
got the zero plate worked out... several things that I forgot to get right when putting the pieces together..
first production mold. still needs work on some areas.
Old Sat 23 October 2010, 05:13
rodom
Just call me: Richard
Roanoke Rapids, NC
Looks good Stan,
The ren board molds I have been working with the past 5 years (made elsewhere) have varied all over the place from smooth to full of chatter marks. These are on the better end of the scale. Nothing that a little body filler and sanding can't fix.
Richard
Old Tue 23 November 2010, 07:05
salewis
Littleton, NC
Talking Time to Beg.... for a serial #
OK guys (and gals sorry), Ted (aka crashingsucks) and I got pushed into painting the MM
We needed a few high quality pictures to be used for display... So Ted cleaned up the garage.. I cut a few more vinyl logos so that the machine would look more finished. Put the logos on the machine...
THEN it happened..... We touched up a section using some flat black spray bomb (sorry aerosol can) paint. We looked at each other and said DANG..
Looks too good to stop (never hear that around a MM ehh)...
Painted the MM, using flat-black (yes we know it isn't standard), but it is kind of hard to find Ford Tractor Blue at 8:30 pm...
Check out the pics... We took some cool shots with low light/directional light but needed a tripod so we won't show them yet....
We are making parts (soon money... )
Old Tue 23 November 2010, 07:25
A Mechmate video game, I like it.
Old Tue 23 November 2010, 07:40
salewis
Littleton, NC
But $0.25US per "play" is getting costly. We hate it when is says "Game Over" before the part is finished..... Almost enough in the coin box to buy us a soft drink (just one, not one for Ted and myself)....
Seriously, we wanted everything together in one cabinet and on wheels. I have a buddy that deals with video/pool tables and he wanted this out of his shop.
Next ticket item in the never finished MM is a new cabinet with touch screen.
But money needs to come in, first.....
Old Tue 23 November 2010, 09:45
rodom
Roanoke Rapids, NC
Wow Stan!! (MM blue or not)
Something's wrong with these photos. That just can't be Ted's garage 'cause I've seen it before. Where did ya move it to?
Doc's been real busy and everything is out in the driveway for these photos if it is his garage.
Richard
Old Tue 23 November 2010, 10:00
Looks like you get #67 !!!
Old Tue 23 November 2010, 10:32
Well done Stan!
(especially with all the covering sheets in the background)
Old Tue 23 November 2010, 15:09
timberlinemd
Just call me: Steve #66
Arizona
Congrats on the new serial number!
Old Tue 23 November 2010, 16:43
Drad98_98
Just call me: Dave #52
Fort Ripley, MN
Looks great Stan, I wonder if the flat black will hold the dust in, like not brush off as easy as a gloss,But I do like the look!! Retro!
Old Tue 23 November 2010, 18:48
Congrats on Number 67!
Old Tue 23 November 2010, 22:46
Pragtig
Old Tue 23 November 2010, 22:47
crashingsucks
NC
Ok they are not all sheets, one is a tarp and another is the canvas for a tent, but in the end they are just like the spray bomb, not pretty but it gets the job done.
Now let me see, I moved a almost moveable Triumph TR3 out of my garage and now I have a chunk of steel that weights as much but I can't ride it,let alone move it......wait it does have a Y-car and we do have a remote control...I think the y-car could hold another 220 pounds....right.
Ok did any of you all notice my last build suggestion, look close, Stan and I hooked up the lights for the coin slots. Hey they were there and I just know the MM will just work better with the lights on....
Oh, after moving all the scrap steel, I think we can build another one!!!! Ready Stan?
Old Wed 24 November 2010, 01:52
salewis
Littleton, NC
I'm up for the task now that we are "what you call experts"...
"Ex is a has-been and a spurt is a drip under pressure."
The sheets cover proprietary stuff just like at my garage proprietary stuff covers my MGB
Yeah, we may find the flat black doesn't release dust well.
Retro.... talk about all the retro stuff that we threw out of the Vid Game console...
Ted wants to build a MAME vid game console, will use the coin door for kicks.. Any ideas on what we could use to cut the console parts with
Old Wed 24 November 2010, 10:11
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Congratulations on Number 67. Now, who is closing in on the much coveted #69?
Workin for Beer #24 - Littleton, Colorado lunaj76 MechMates already cutting 133 Wed 09 May 2012 08:35
Vacuum Table.... salewis 10. Base Table 5 Mon 08 August 2011 21:23
Flower Carvings and Skateboards! - Littleton, CO lunaj76 The Show Room 15 Wed 20 July 2011 21:46
vacuum table question tldj55 General - MM Build 1 Sun 23 January 2011 19:53
