Old Sun 22 November 2015, 20:20
racedirector
Just call me: Bruce #122
New South Wales
Thanks Gerry, I am happy to be corrected. Please note I did not say windows software in general, I said "the windows software" meaning Mach3
What my decision came down to was a) I am cheap and b) hate Windows with a passion , the former being a definite consideration when running 2 or more machines.
Old Mon 23 November 2015, 02:50
Getting back to "Mach 4 info", has anyone got a good look or try at it yet?
Old Mon 23 November 2015, 06:07
alan254
Just call me: Al #95
mystic ct
From the old school, if it works don't fix it.
Old Mon 23 November 2015, 06:26
Tom, I have only played with the demo. Since I run parallel port and not a separate motion controller, I have not had the chance to run it yet.
Old Mon 23 November 2015, 18:40
ger21
Just call me: Ger
Detroit, MI
Pete, you can download the Mach4 parallel port driver and run it in demo mode, but it's very limited in the number of lines of code it will run. (I think)
Old Thu 10 November 2016, 02:34
Helsingtwelve
Just call me: James
Houston
Setting up Mach4 With ESS on Windows 7 64
I'm running my machine with Mach3, and looking for a good price on Mach4, and I need help setting it up I spent too much time on the Demo, and something is wrong in my setup, or I might not be following the proper instructions.
Here we go
Old Thu 10 November 2016, 04:41
ger21
Just call me: Ger
Detroit, MI
I think the only way to get a better price on Mach4, is to buy it in a package with a motion controller.
Mach4 is much more difficult to setup than Mach3, and it's still not finished, after 5 or so years of work. Also, most motion controllers do not have fully functional plugins yet either.
Old Fri 11 November 2016, 12:55
Helsingtwelve
Just call me: James
Houston
Mach4 help setting up
Yes I have it on my "Fire in the Hole" Computer, it can break down any thing fast but in 8 Days no Movement
it's just should we say not ready!!!!!!! Aaaaaaaaaaaaa uuuuuuuuu
Old Fri 11 November 2016, 13:10
Helsingtwelve
Just call me: James
Houston
Ethernet Smoothstepper Mach4
Ethernet Smoothstepper runing Mach3, and attempting to run Mach4, of course one at a time this is how it looks
Old Sat 12 November 2016, 08:22
What benefits while running a router can there be with Mach4 instead Mach3 that are worth the trouble
Old Sat 12 November 2016, 08:28
ger21
Just call me: Ger
Detroit, MI
At some point in time, no bugs and a better trajectory planner.
But there are easier to use options that offer that right now.
Welding Info Metalsmith Miscellaneous / General / Whatever / Catchall 1 Sat 28 April 2012 14:56
Relay info m_leblanc 70. Control Systems 8 Sat 23 January 2010 20:44
Info - all in French yamsx600 General - MM Build 2 Sat 04 July 2009 11:07
How to find INFO on stepping motor's? allan-p Archives 2 Thu 11 December 2008 23:44
Upgraded Mach, now the motors won't turn - Different ports/pins for later Mach Hugo Carradini Troubleshooting 19 Thu 25 October 2007 11:45
