3d routing of EVA foam
Hi,
Looking for any info on routing EVA foam. Is it even possible to get good 3d cuts in this stuff? I have had very little practice cutting it. Having a hard time finding a guru in EVA FOAM 3d routing. Any help or lead would be of great help. Thanks Justin |
Justin,
Visit http://www.hartlauer-bits.com/ or call him to discuss the right cutting tool for this foam. It's flexible, It's soft...usually requires a decent vac holddown to keep it from moving or cupping up into the tool if your pocketing a large area in the middle. I don't have a lot of experience, but I have cut it. |
Thanks Sean!
| How do you charge routing services? | kanankeban | The Show Room | 1 | Fri 23 December 2011 10:56 |
| Routing or cutting aluminium | WARBIRD | Cutting various materials - bit selection, feeds, speeds | 21 | Sun 31 May 2009 13:09 |
| Onsrud CNC Production Routing Guide | sailfl | Cutting various materials - bit selection, feeds, speeds | 1 | Sat 02 May 2009 23:49 |
| Cutting Foam Core Board | jhiggins7 | Cutting various materials - bit selection, feeds, speeds | 3 | Fri 17 April 2009 13:26 |
| Routing the flexible dust hose | MariusL | 55. Dust Management | 7 | Tue 10 February 2009 01:32 |
