Old Wed 04 August 2010, 12:03
...all those work. Be careful, porous sheets (like MDF and cellulose) will often pick up 1, 2 or 3 sheets at a time.
Melanime and plywood, respectively in the videos are fairly NON porous and will grab only 1 sheet at a time.
....for what it's worth.
Old Wed 04 August 2010, 12:17
Regnar
Just call me: Russell #69
Mobile, Alabama
Sean I think Pmk was talking about the front loader found here http://www.woodmotion.com/front_loader.php
No vacuum just mechanical lift.
Old Fri 09 November 2012, 23:32
Regnar
Mobile, Alabama
Adding another video of a DIY version.
http://www.youtube.com/watch?v=IsFt-...q1H5E9wEAzld2Q
Old Sat 10 November 2012, 19:38
zumergido
Just call me: Fernando
BS AS
mm that can be a great add-on for my employee.
anyone know if a vacumm pump like this will be enough. with a small tank.
like 120 -200 liters per minute depends on the model.
Old Sat 10 November 2012, 20:29
Nope this is not even close. This is a low flow high vacuum type. you need at least medium flow type to compensate for the vacuum lost through mdf porosity & other leakages.
Old Sat 10 November 2012, 22:05
Regnar
Mobile, Alabama
It does sound like he is using a Venturi and some kind of Air driven drive to lift the sheets. Both should be availible for much cheaper than the pump.
