Old Tue 11 September 2012, 10:05
lunaj76
Just call me: Justin #24
Littleton, (Colorado)
mechmate 3d printer?
Can we convert the mechmate to be a 3d printer? I haven't looked into this yet just thought I would get some feedback first.
Justin
Old Tue 11 September 2012, 11:19
Justin,
I think this could be done, as the 3d printers are nothing more than light duty cnc routers with a heated extruder end. So you should be able to make an extruder hot end for the MM. The only other problem I might foresee is if the software will work ok with the drivers we use. Dont take this as gospel, as I have not done a lot of research on these but my gut is saying it should be able to be done.
Old Tue 11 September 2012, 15:17
it would work but very slow. laser cutters and 3d printers require very high speeds and acceleration to be profitable, you don't want to leave a mechmate printing for 48 hours
investigate more on http://shop.seemecnc.com/
and look for Hoss on cnc zone, he is now seriously printing after all the cnc milling machine modifications.
Old Tue 11 September 2012, 19:15
lunaj76
Thanks Danilo that was good info!
Printer Cable Sources smreish The Market Place 0 Mon 14 March 2011 13:17
running stepper motor with printer data pcb board helow 701. Motor Drives 1 Mon 14 June 2010 06:30
Printer Friendly Version? Regnar About this Forum 15 Tue 02 February 2010 11:46
Printer Cable Box - Connector sailfl 70. Control Systems 2 Sun 21 September 2008 21:19
