Old Wed 25 April 2012, 04:51
giggler
Just call me: giggler
na
Step value?
It seems a common choice of motor is all-in-one with gear box having a ratio of 7.2. Also a common pinon on an output shaft is 36teeth. I went for mod 1.
Question, if most these common combinations result in steps that are not a nice round number, what step figures are you guy's using with your build?
I found I had to use a fraction because rounding up to 0.015mm/s as per Mechmate excel sheet, produced to shorter cuts.
giggler
UIM 240xx step driver help. window_s CNC motion control software 13 Mon 01 August 2011 06:17
my first step , v rails oscaryrc Introduce yourself and start planning 5 Thu 12 August 2010 00:19
Slight step over on second/third pass Dan Sj0 Troubleshooting 2 Sat 10 July 2010 06:55
STEP 1 - Introduce myself, FFEJ from Geelong ffej Introduce yourself and start planning 8 Fri 22 January 2010 02:20
Mounted X-rack's with different heights - causes step at joint. Barman Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 10 Tue 17 March 2009 08:03
