Old Wed 18 April 2012, 04:31
I am very familiar with this problem. Things to check because this is how I found the issues on Machine #28.
Machine type 5 x10
Columbo 2.2 KW spindle w Delta B series VFD.
- what it did....when spindle was on, the z would randomly go up and down, almost oscillate. The y car did the same randomly, but not as much.
Problem(s) found.
- improperly terminate shield on the step/direction wire from the BOB to the Gecko.
- ground issue on whole machine that required the following changes:
1) add relays to outbound button interface boxes on machine to isolate BOB from stations.
2) isolated the proximity switch circuit which was the final cause of the interferance
3) added an isolation transformer for the VFD only to keep ground issue away.
All the above where required for this machine to function properly.
Good luck with your troubleshooting.
Old Wed 18 April 2012, 04:51
........Problem(s) found.
I don't get 1) what are you refering to "outbound button interface boxes"?
3) isolation transformer is one expensive solution. Ever tried connecting RFI/EMI filter? it works for me.
Old Wed 18 April 2012, 08:02
Ken,
The buttons on the machine that are pause, resume (green and yellow).
These buttons, when not isolated between the J header on the BOB and the outbound buttons, induced noise to the BOB. Thus, had to isolate those hard buttons from the BOB by use of a FORM C, relay contact to resolve the closure to the BOB.
Filters didn't work - Transformer was a last resort. (and I just happened to have one sitting in the corner of the shop)
Old Wed 18 April 2012, 22:11
Sean,
Thanks for clearing my misery
You sounded like a fellow hoarder...
Old Wed 25 April 2012, 14:48
Conrado_Navarro
Just call me: CONRADO NAVARRO #55
OBREGON
Mexico
Send a message via MSN to Conrado_Navarro Send a message via Yahoo to Conrado_Navarro
Thumbs up
Hello :
Just to let you know that problem is Solved.
After rewiring the control box, grounding here and there, everything is working perfect.
Thank you for your help
Old Thu 25 April 2013, 08:55
Conrado_Navarro
OBREGON
Mexico
Hello:
mechmate number 55 is still going strong, we even put to work a Chinesse CNC Router for a friend, thanks to the knowledge acquired in this fórum, nobody was quialified in this área.
Here is my webpage https://www.facebook.com/CncDisenoDi...ookmark_t=page
Old Thu 25 April 2013, 11:34
Welcome back!
Old Thu 25 April 2013, 12:59
Conrado_Navarro
OBREGON
Mexico
I never leave, I always read the new post and stay informed about the fórum I just not post much
Old Mon 18 November 2013, 12:38
Conrado_Navarro
OBREGON
Mexico
Hello every one,
Long time without a post
but I just want to let you now that my mechmate still Running Ok,
I know we Like Picks, I added a facebook page where I put my mechmate Work
I hope you like it
Best regards
It Cuts the Wood and Aluminum #76 - Guadalajara, Mexico rceja MechMates already cutting 85 Sun 17 November 2013 06:26
It runs! #89 - Monterrey, Mexico kanankeban MechMates already cutting 118 Tue 17 January 2012 18:42
Mechmate Parts for sale w/photos. Finally stphnd22 The Market Place 14 Wed 07 September 2011 20:25
Mechmate cutting in Puebla TimWerding Introduce yourself and start planning 3 Sat 21 May 2011 08:25
3D Elk cutting (video) #13 - Hagerman, New Mexico Greg J MechMates already cutting 415 Sat 05 September 2009 20:28
