#61
I have placed this tread out of the general build area as it appears this device will not be following the standard. I will be keeping an eye on the thread to see how it may benifit the MechMate group going forward.
Have fun with your build and if you do decide on the MechMate design, I will place your thread back over in the build area. |
#62
MetalHead,
It all comes down to the money, I'm basically removed. Thanks, Vern |
| Direct motors 4Nm and 6,8Nm | tomasptacek | Motors & their mountings | 0 | Wed 26 May 2010 02:25 |
| Newbie needs help with figuring out drive configurations (slaved drive for x-axis) | ikeike | 701. Motor Drives | 5 | Mon 04 January 2010 21:06 |
| Slaving a motor - put its drive in parallel to another drive on the same BOB output | J.R. Hatcher | 70. Control Systems | 34 | Mon 16 November 2009 09:13 |
| Automation Direct power supply . . . or a Switch Mode MeanWell | bfauska | 702. Power Supplies | 14 | Tue 11 August 2009 10:16 |
| MechMate in Arizona | Kevin | Construction started, but not cutting yet | 7 | Sat 22 December 2007 10:52 |
