Old Tue 19 July 2011, 15:39
coinhunter
Just call me: coinhunter
Bogota
Colombia
Problems working the end of some Ballscrews
I have some problems working the end of some screwballs, they are really hard and the lathe doesn’t “clean” the thread of the screw, I think that it would be a good idea to heat them in order to “soften” the metal, is it a good idea? How can I solve this problem, thanks for your help.
Old Tue 19 July 2011, 17:42
use the grinder to remove the top cemented coating, then machine the soft insides.
And use ceramic inserts as they should be rated for 65hrc, if you go real slow with them you can skip the grinder, but its the easiest way.
Old Wed 20 July 2011, 00:13
coinhunter
Bogota
Colombia
Originally Posted by coinhunter View Post
I have some problems working the end of some ....., they are really hard and the lathe doesn’t “clean” the thread of the screw, I think that it would be a good idea to heat them in order to “soften” the metal, is it a good idea? How can I solve this problem, thanks for your help.
Sorry, I wanted to say ball- screws!!!
Old Wed 20 July 2011, 17:41
So is this a MechMate using ball screws ?
Old Wed 20 July 2011, 22:01
coinhunter
Bogota
Colombia
It is a homemade CNC machine, the model doesn't look like a mechmate. I don't know how a "Mechmate" moves his axis, in my case they are moved by the ball-screws.
Old Thu 21 July 2011, 15:06
Travish
Just call me: Travis #75
Wa
The material is case hardened and around .06" deep depending on your ball screw size. Use carbide and get your surface speed down to where it should be, And the tool will bite and cut real nice. The material is soft under there after you get thru the case of the material. There are other materials that will cut it just fine but not as forgiving. Fosus on the right rpm based on the surface speed needed and you will be good. Just don't work harden the material. There are many factors that may contribute to your problem, so it's hard to list them all. Good luck!
Working on Belt Drive - Randers Denmark IN-WondeR Motors & their mountings 0 Sun 09 January 2011 08:23
Power Contactor Not Working Regnar Troubleshooting 28 Sat 10 April 2010 13:38
Working with CAM Software - Shawinigan, Canada m_leblanc Introduce yourself and start planning 28 Mon 22 March 2010 00:53
Experience on working with V-cap rails 711man Rails & Rollers 0 Mon 21 September 2009 09:03
