Go Back   MechMate CNC Router Forum > Common Assemblies & Parts > Profiled (laser cut) & bent steel plate
Old Wed 13 April 2011, 03:21
sh.y1234
Just call me: Yosef
MODIIN
Israel
Tolerance of laser cutting
Hello everyone !
The laser company ask me what is the tolerance i need
for the laser cutting and bending
any help will be appreciated
Yosef
Old Wed 13 April 2011, 06:52
I have never been asked that question by the 5 different companies that do this work for us. Tell them you want their normal quality and have a look at their samples.
Old Wed 13 April 2011, 07:59
IN-WondeR
Just call me: Kim
Randers
Denmark
Normally they will do cutting within 1/10 of a mm, and bending will be almost dead on, on angles.
Old Wed 13 April 2011, 08:00
isladelobos
Just call me: Ros
Canary Islands
Spain
I think You can ask for best tolerance they have. if the same price.
Is possible 0.1mm is normal for laser.
Old Wed 13 April 2011, 08:25
The basic design of the MM will allow the laser cutting to be off by more than 0.1mm, maybe even 0.5mm is okay. Therefore, do not ask for any special work at higher prices. Just their normal work, at normal prices should be fine.
Old Fri 15 April 2011, 06:38
sh.y1234
Just call me: Yosef
MODIIN
Israel
Thank you all !
Yosef
Old Mon 25 April 2011, 11:21
rischoof
Just call me: Rik #92
Goirle
When I have a job for my lasercuter, I print out a drawing and a place a circle arround the important tollerances in the shop. so he can see what I want. My motorplates were cut inlucing the holes for mounting the bearings. the only thing I had to rework was the place were the laser starts and ended cutting. also the hole was a little tappered. so depending on which site I had to mount the bearing, I had to adjust a little bit. this took only a couple of minuts. I could mound the bearings by pushing them in by hand !!
Laser Cutting and Bend Service slobato Archives 2 Mon 04 April 2011 21:07
Tolerance in length of y-beams Red_boards 20. Gantry 10 Wed 26 January 2011 16:57
Laser Parts cutting with cnc router asif3244 Profiled (laser cut) & bent steel plate 4 Wed 01 December 2010 09:36
Laser Cutting Parts lisawaa The Market Place 6 Tue 14 September 2010 12:07
Laser cutting in various countries . . . . vadeem Archives 12 Thu 02 October 2008 07:02
