#31
Ross, I also admire your perseverance on this Modbus thing.
Although modbus would be the bees knees there are other options. Peter Homann makes the Digispeed right here in Victoria. http://homanndesigns.com/store/index...products_id=21 This will give you control through Mach3 of CW (and CCW if you want) and speed (RPM) I would like to see you succeed with the modbus, but maybe it is time to try another way. I am even more interested in Skippy's efforts with the Hitachi VFD, as I am trying to do the same thing, and so far having the same issues that he is. Greg |
#32
Ross, The mot common Potential meter are volume controls for audio equipment. you have choice of 1k ohm to 1M ohm. Linear or log scale. cheap & effective.
#33
Hi Greg
Good advice. Peter Homann responded with amazing speed to my email and recommended the DC-03 DigiSpeed GX V3 as you have. Given some of the outlays on the machine his delivered price of $50 seemed very reasonable. As money is no shortcut to understanding, I have some manual reading ahead of me. Once I have something significant to add, I will document my adventures / misadventures. Thanks Ken for the tip on the audio pots, if I need to use one your my man.!! Regards Ross |
#34
Got it
After declaring the end of my tether, today I ignored that and conducted a further test and got a perfect result.
24,00 RPM stops and starts, ran code over and over with it working everytime. Ran the tests so many times Mac3 was suggesting it was getting sick of running the "fish in the bowl" test Gcode that was a known failure previously ![]() The problem with the communications between Mach3 and the VFD is the adapter that everyone is using. For those of you who are willing to read my build thread, the link to the product that will work is there for you all. A sample of one is a bad sample so now over to the rest of you to independently verify my findings. Happy - you bet ! Regards Ross |
#35
Thats great news Ross!! your persistance has finally paid off!! so what finaly done the trick?? and do you have everything else wired up now??
Cheers Tony. |
#36
Hi Tony
I just posted the wash up for all to see in my build thread. And yes I know I'm bad, I promise to stay out of the Hitachi Modbus thread from now on until I actually know something. ![]() Regards Ross |
| Mach 3 CV settings | Greg J | General - MM Operating | 2 | Wed 17 November 2010 15:49 |
| Mach 3 | sailfl | 80. Computer Hardware & Software | 6 | Mon 13 September 2010 14:03 |
| mach 3 setup help | paul60 | 70. Control Systems | 7 | Tue 03 August 2010 12:02 |
| Shopbot VS Mach 3 | Cutter99 | CNC motion control software | 46 | Mon 22 June 2009 05:21 |
| Upgraded Mach, now the motors won't turn - Different ports/pins for later Mach | Hugo Carradini | Troubleshooting | 19 | Thu 25 October 2007 12:45 |
