Old Thu 11 March 2010, 23:01
cvriv.charles
Just call me: charles
New Jersey
Thanks. I am planning to use high grade 3/8" bolts too. The thing im worrying about is that im using 3 X 1-1/2 X 1/4 (6.0#) channel for everything under the mainbeams. Cross bearers, legs, etc. Thats very heavy. Im wandering if I use an appropriate number of high grade 3/8" bolts that I'll be fine? What do you think?
I was thinking maybe I should use 1/2" but thats seems like overkill to me. 3/8" bolts are pretty big/ strong.
Old Fri 12 March 2010, 00:16
DeadGuy
Just call me: Dennis #51
Astoria, Oregon
Hi Charles,
3/8 will be fine, but if I do this again(and I will) I will be using all metric bolts. To many things you buy for this, like steppers or the wheels, all use metric bolts. It was a lot of switching back and fourth and it gets to confusing.
Dennis
By the way I think I have a reservoir you built. DarthBevis gave it to me.
Old Fri 12 March 2010, 00:27
cvriv.charles
New Jersey
Originally Posted by DeadGuy View Post
Hi Charles,
Dennis
LOL! Really? How is good ole surroz doing? Wow, its a small world. I plan on making some newer and better reservoirs with my MM. I'll dedicate one of the first to you
Anyways thanks for the advice
And another MM will be built in Belgium bramvh Introduce yourself and start planning 9 Fri 15 April 2016 14:01
Hi guys. Kurt Rose Introduce yourself and start planning 4 Sat 13 February 2010 15:41
Before I buy could you guys please check my purchase Regnar 702. Power Supplies 2 Mon 18 January 2010 21:31
heres some guys could use some help from Art revved_up Miscellaneous / General / Whatever / Catchall 0 Tue 24 March 2009 09:52
What are the limitations of a MechMate compared to the $50 000 machines? Gerald_D General - MM Build 19 Sat 14 March 2009 10:17
